Ok so wiggling the wires again netted me nothing this time so here's a new thought back when this started I had similar symptoms to now so here it is
The eec relay takes power from somewhere, e.g. a failing sensor hopefully not some random wire, it loses power and flicks open and closed so many times it burns up problems get worse it starts to die and stay dead etc.
So what could cause that to happen where does the power come from for the relay and or what sensor could cause that
The diagram is showing the full path. The return path for the coil is to ground G100. If the resistance is high, you have a problem in reference to ground. There is no sensor or other piece in the circuit.
I'm guessing it's fixed because I had no issues with my entire weekend in Vegas
there was a 3/8 bolt that fell out from under the dash on the trip back though I'm guessing that's why the steering column moves when you hit the clutch
