anyone have projector headlights?
Old Oct 1, 2017 | 09:47 PM
mcali2's Avatar
mcali2
I am looking at doing something to get more light. darn cars have brighter lights than the old trucks do on hi beam. I could go with HID but they are low beam only still brighter. I also thought about adding a light bar in the bumper and i know that will be bright but may get me into trouble. I drive areound now with high beams on and no one flashes me. Just goes to show how bright cars are now.
Old Oct 2, 2017 | 06:42 PM
Fuzzynuts's Avatar
Fuzzynuts
Phillips X-treme Vision bulbs help, along with the relay wiring mod.
Old Oct 2, 2017 | 10:34 PM
mcali2's Avatar
mcali2
what is the relay mod? ,ake both hi and lo at one time?
Old Oct 3, 2017 | 06:30 AM
97-psd's Avatar
97-psd
I don't believe so. I believe it just helps to make sure a full 12 volts get to the headlights. It helps them work at full voltage which makes them brighter. A pretty common mod on old Jeeps too
Old Oct 3, 2017 | 09:29 AM
7.3 forever's Avatar
7.3 forever
If ur want brigh headlights I’d buy a set of new clear headlights and pickup a set of cheap diy projectors on eBay and a hid set for 9007 and then get bulbs for the projectors trust me works great and not near as exspensve as other kits built 2 sets of headlights like that going on a year now no issues
Old Oct 3, 2017 | 09:31 AM
7.3 forever
IF you have any questions shoot me a pm and Id be glad to give u details and how I separated housings and put them back together
Old Oct 3, 2017 | 06:46 PM
Fuzzynuts's Avatar
Fuzzynuts
Yeah, the factory power comes through the headlight switch on the dash with small wiring. You can buy or make a harness that draws power straight from the batteries and just uses the switch as an on/off, as it should be.
The X-treme Vision bulbs are brighter at the cost of reduced life. Output is up at the legal limits.
Old Oct 4, 2017 | 09:46 AM
mcali2's Avatar
mcali2
Sure like to know how you did it. Would make a good thread you know.
Old Oct 4, 2017 | 10:37 AM
7.3 forever
Best thing to do is buy a hid kit with high and low there all over ebay but the high low option never seems to work with the bulbs you get in the kit then look up and find high low projectors on eBay get a mid range priced one most I’ve seen that are high and low with a shroud run a h1 bulb then buy a set of replacement h1 bulbs or whatever bulbs fit ur projectors you buy then just simply take ur new headlights and throw them in the oven on 200 for 15 minuets and remove them and leave the oven on slowly pry around the edge of the lense u may half to put it back in oven a few times once you get it removed you can start figuring out Home ur projectors will mount most the time you half to cut the outter original ring off that the original light sockets to and the ur projectors have a rubber oring type gasket on them you will put in and install the nut from the back then take and clean all ur original glue out of the seam of your headlights and I use the same stuff the put between metal roofs sheets to seal it roll it in a round like string and push the lense back on and put it back in oven for few minutes then remove push on the lense and your good to go I’ll try to post all the pics I have of the process but it’s fairly simple really
Old Oct 4, 2017 | 10:50 AM
7.3 forever
Two of those pics are from eBay there different projector options as long as there high low and have the hardware with it they will work with a bit of modifications to the headlight housing it’s self but is a worth while upgrade you can adjust them with your factory adjusters and there just as brigh as factory new cars if you do this modification you won’t regret it trust me
Old Oct 5, 2017 | 08:04 PM
MI02SVT's Avatar
MI02SVT
https://www.theretrofitsource.com/complete-retrofit-kits/universal-kits/bixenon-morimoto-fxr-stage-3.html
Get this kit look up installs on their website you'll love it
Old Oct 5, 2017 | 08:41 PM
Fordman96's Avatar
Fordman96
This is the ones I'm going with
http://outlawleds.com/1992-1997-ford-obs-headlights-double-halo/
Old Oct 6, 2017 | 12:17 AM
mcali2's Avatar
mcali2
outlaws look nice but H1 and h7 bulbs I want HID.
Old Oct 6, 2017 | 08:08 AM
7.3 forever
I can’t speak for those kits but I’ve read multiple threads on different sites and people have bought kits from multiple companies but I guess it depends on how much time a person is willing to put into it also you half to make sure you get a projector made for hids atleast that’s what i understand from everything I’ve read I just searched hid projectors on eBay also you can buy h1-h7 bulbs in hid
Old Oct 8, 2017 | 11:41 AM
97-psd's Avatar
97-psd
Those outlaw sets look sweet. I like the tail lights too. A bit pricey, but there aren't many options out there
DrewF
6.7L Power Stroke Diesel
31
May 11, 2012 08:40 AM
84 f250 6.9
19
Feb 12, 2010 06:29 PM
ford7379trucks
Feb 5, 2010 04:27 AM
rupejosh
37
Jun 11, 2009 11:45 PM
Mat J
May 10, 2009 04:46 AM
