Hey Guys, I've been trying to find one info on tire size/lift height on this truck. I'm thinking 4" lift on 36's but can't know for sure. Tried emailing the company but haven't heard anything in weeks. Can anyone help me out?
Thanks.
The fender badges look like they say f350. If so it may just be a leveling kit on the front and stock rear heighth with ~35" tires. Can't tell what kind of leveling kit. Looks good
It's hard to tell because of those huge fender flares, but it sort of seems like maybe the fenderwell has been trimmed a little bit. Maybe a slight lift too. My 97 ext cab 4x4 has about a 6" lift and around 35" (metric) size tires, and I have more noticeable gaps in the wheel wells and my truck looks a little taller than this truck does. It doesn't look nearly as good though.
35s on a stock suspension with a front add a leaf to compensate for a 650lb bumper/winch, yes front bumper is not stock but if you match the offset properly its more than doable.Under full flex there is slight rubbing on the leafs but that is it.
I can't see those being bigger than 35s and at most a 4" lift in that picture.
