PSOM Reprogram Mileage Reading
Old Dec 16, 2018 | 11:04 PM
  #46
wtroger's Avatar
wtroger
I know it can be done. I had a badly damaged ic on my van. Ford wanted over $600 to get and program a new one. I picked up a salvaged one with way more miles then mine and had a place set the mileage on the new one to what was on the old one. Works perfectly.
Old Dec 17, 2018 | 07:13 AM
  #47
kb2672's Avatar
kb2672
Originally Posted by ifrythings
The one I just pulled off of a psom starts drawing current around 24v
Thank you, thank you, thank you! Now, at least I know which one to buy.
Old Dec 17, 2018 | 07:15 AM
  #48
subford's Avatar
subford
Then if the parts work for you would you please post the part numbers back to this Thread.
Old Dec 17, 2018 | 07:18 AM
  #49
kb2672's Avatar
kb2672
I'll do that once I see if it's going to work.
Old Dec 17, 2018 | 07:20 AM
  #50
subford's Avatar
subford
By the way the same metal oxide varistor is used the same way in either or maybe both the tachometer and the RABS module.
I read somewhere they use the same type power supply.
Old Dec 17, 2018 | 04:45 PM
  #51
Eddiec1564's Avatar
Eddiec1564
The clamping voltage for the MOV's in automotive applications are usually 18V to 24V.
Old Dec 26, 2018 | 10:14 PM
  #52
PRIMERED79 SHORT BED's Avatar
Oh man, light at the end of the tunnel...Hopefully this works, tired of seeing 300k on my truck whens its only 140k ha.
Old Jan 25, 2022 | 06:39 PM
  #53
Bringing this thread back from the dead.
Not to long after this I swapped back to my OG cluster as I couldn't stand looking at 300K on the clock and put the lightning cluster in a box with my other spares I had and on the shelf it went.
Since I work on the road and never home long enough I forgot all about it.
Since work has been slow I have been home more than I ever have since 2015 and decided to start selling my stash for the extra money.
Sold all but one of my clusters and my lightning cluster and decided to tackle this once and for all. I started to look into reprogramming the eeprom but didn't get any further than last time, and started to price the equipment to do it, some of it is not priced terrible high, but it racks up there and I don't know for sure what else I may need besides a burner.
So I did a web search for odometer correction and lucky me there are folks one hour away from me that do that type of work.
So called them up and scheduled a drop off time, and a few days later dropped it off on a Friday, got a call today around 11am telling me they had it done.
I did have to plug in the lightning cluster because they needed to know how many miles were on it, but I just want to let everybody know about these folks and if your needing odometer correction done I would highly recommend them.
Link to their website.... https://www.automotivecircuitsolutions.com
Lightning Old mileage.
OG truck cluster mileage.
Original mileage spot on.
Old Jan 26, 2022 | 01:56 AM
  #54
AuroraGirl's Avatar
AuroraGirl
Those ****ing needles are supposed to be YELLOW? Holy. (when not lit)
thats funny. would have just guessed white based on mine LOL
Old Jan 26, 2022 | 06:48 AM
  #55
evan_nugget's Avatar
evan_nugget
I believe the lightning clusters had the yellow needles, the normal trucks are white. Mine are white as well.
Old Dec 17, 2022 | 01:48 AM
  #56
ford cali's Avatar
ford cali
1st Gear
Originally Posted by technobabble
Subford, all you need is a base set of eeprom data, edit it by hand, and write it back to the chip. Nothing magic. Could just as well use the data you posted as a base to edit for any mileage.
Eddiec1564, I didn't figure out the entire encoding scheme, but I got pretty close. Close enough to write any value I want within a few K miles.
If I can get a nod from an admin, I'll post the info. I don't see the harm considering the age of this PSOM, but I don't want to post it if it's going to be a concern.
I have pulled eeprom data from psom and it looks different . It is in a 1997 ford f250 .
Old Jul 4, 2023 | 02:07 AM
  #57
pcwizzy37's Avatar
pcwizzy37
5th Gear
I've been working with the PSOM and eeprom for a few days now. I upgraded my 88's mechanical speedo with the 92ish one from junkyard, but wanted the mileage to match the mechanical one. So I did, right down to the tenths. So my question is, can I post my findings here? Perhaps a moderator/admin can chime in on this. The info will allow anyone who can program an eeprom to put any mileage they want on this PSOM. Post or no post?
I'd love for you to post it or at least PM me, I put a '92 PSOM in my '91 F-250 to asccomodate the new transmission with no speedo cable engravement in output shaft so sending what you found would be much appreciated.
Old Jul 31, 2025 | 07:19 PM
  #58
Ballo's Avatar
Ballo
Did anyone figure out how to reset the tire calibrations? I have one left but there doesn't seem to be a way to test the ratio before committing it
Old Jul 31, 2025 | 11:12 PM
  #59
wwhite's Avatar
wwhite
You need to figure out the conversion constant first.
1983 Ford Bronco PSOM picture | SuperMotors.net
Old Aug 2, 2025 | 05:36 PM
  #60
Ballo's Avatar
Ballo
Is there any way to test the ratio before committing it?
GuitarJesus
18
Sep 4, 2018 12:29 AM
coreylasalle
Apr 2, 2014 08:34 PM
crossy
Feb 5, 2013 11:24 AM
DOHC
Oil & Lubrication
Feb 9, 2005 10:53 PM
misti430
Apr 16, 2002 08:27 AM
