PSOM Reprogram Mileage Reading
Old Nov 30, 2018 | 01:18 PM
  #31
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by evan_nugget
Always was curious, why does it do this?
My best guess is ford was to chap to put the line in for the top left corner of the 4
Old Nov 30, 2018 | 02:36 PM
  #32
subford's Avatar
subford
The mileage is stored in binary.
A 4 would require a word one place more in the register.
A 3 is a 11 where a 4 is 100.
399,999 = 1100001101001111111
400,000 = 1100001101010000000
Old Dec 12, 2018 | 12:03 PM
  #33
technobabble's Avatar
technobabble
I've been working with the PSOM and eeprom for a few days now. I upgraded my 88's mechanical speedo with the 92ish one from junkyard, but wanted the mileage to match the mechanical one. So I did, right down to the tenths. So my question is, can I post my findings here? Perhaps a moderator/admin can chime in on this. The info will allow anyone who can program an eeprom to put any mileage they want on this PSOM. Post or no post?
Old Dec 12, 2018 | 04:32 PM
  #34
subford's Avatar
subford
You have to have an EEPROM with the mileage in it to copy to another EEPROM.
I do not know of any computer program that will translate your mileage into information to burn into a EEPROM.
The information needed example.
Attachment 284286
Old Dec 12, 2018 | 04:43 PM
  #35
Eddiec1564's Avatar
Eddiec1564
So you figured out how the mileage data is encoded in the EEPROM?
Old Dec 12, 2018 | 06:12 PM
  #36
technobabble
Subford, all you need is a base set of eeprom data, edit it by hand, and write it back to the chip. Nothing magic. Could just as well use the data you posted as a base to edit for any mileage.
Eddiec1564, I didn't figure out the entire encoding scheme, but I got pretty close. Close enough to write any value I want within a few K miles.
If I can get a nod from an admin, I'll post the info. I don't see the harm considering the age of this PSOM, but I don't want to post it if it's going to be a concern.
Old Dec 13, 2018 | 04:30 PM
  #37
subford's Avatar
subford
If you want email me the information. I would like to see what you have.
My email address is at the bottom of this post.
Old Dec 13, 2018 | 05:24 PM
  #38
technobabble
Ummm ... if I can get a go-ahead, everyone can see it.
Old Dec 14, 2018 | 06:24 PM
  #39
rdayt's Avatar
rdayt
Ford might have an issue with you reverse engineering their software. Especially if you publish it.
Just sayin'
Randy
Old Dec 14, 2018 | 10:35 PM
  #40
technobabble
Just sayin'
Randy
Yes, I agree completely in the event I was reverse engineering their software. I had concerns with this, and did a little legal digging just to be sure. This isn't what is going on.
Their software, runs on the main CPU. The eeprom is simply a storage medium to store/read data. Anyone with an eprom reader can view/edit/modify it. If I discussed the encoding and format of that data, I agree that might be an issue, so I have no intentions of doing that. My discussion scope would be limited only to a "here's what I observed" style of posting. The reader would be free to draw his/her own conclusions from what I observed.
On a side note, I would never even mention any of this for the newer vehicles. Remember this PSOM module is 20+ years old. Those vehicles are becoming antiques.
Old Dec 15, 2018 | 05:21 PM
  #41
EllieMae94's Avatar
EllieMae94
Too much suspense. Spill the beans, we all want to know!
Old Dec 16, 2018 | 12:19 AM
  #42
kb2672's Avatar
kb2672
That makes perfect sense! On a side note, since Ford no longer manufactures these PSOMs, does anybody have a schematic of the PSOM board and it's components? I'm interested in the part numbers or ratings on the metal oxide varistor and the surface mount diode in the power supply circuit. I need to replace these on my PSOM.
Old Dec 16, 2018 | 09:00 AM
  #43
subford's Avatar
subford
Best I can do at the moment.
Attachment 280346
Old Dec 16, 2018 | 08:02 PM
  #44
kb2672's Avatar
kb2672
That's helps alot! Thank you! Now, if I can figure out the proper clamping voltage for the MOV, I'll be in business.
Old Dec 16, 2018 | 09:46 PM
  #45
ifrythings's Avatar
ifrythings
The one I just pulled off of a psom starts drawing current around 24v
