393 injectors
Old Oct 1, 2017 | 04:20 PM
vintageracer31's Avatar
vintageracer31
393 injectors
Hi All, I built a 393 for my 1990 F150 2wd and have been driving it for a year. It is used mainly to tow my vintage modified on a open trailer to the races. It has a marine cam for better torque and 4 hole injectors because of the cubic inch. It tows well but seems to run a little rich and the mileage without the trailer at best is 15 mpg. I thought about putting the stock 19 lb injectors in but I don't want it to be too lean. Anyone else have a 393 as a truck motor?
Old Oct 1, 2017 | 04:40 PM
Conanski's Avatar
Conanski
You can't just change injectors ***** nilly without reprogramming the PCM, so what injectors are you using and what is the PCM programmed for?
Old Oct 1, 2017 | 04:47 PM
vintageracer31
The 1990 has a OBD1 computer. As far as I know it can't be reprogrammed. I have 24 lb 4 hole injectors in now. The truck had 19 lb single hole from the the factory
Old Oct 1, 2017 | 05:08 PM
Conanski's Avatar
Conanski
You're using a stock 5.8 computer? What cylinder heads? What cam?
Old Oct 1, 2017 | 05:17 PM
vintageracer31
Yes stock computer and heads. I'm using the 351W marine cam which is a torque cam. That's the only mods I have done beside eliminating the converter and EGR valve
Old Oct 1, 2017 | 05:59 PM
Conanski's Avatar
Conanski
OK, then you should be using the stock 19lb injectors.
Old Oct 1, 2017 | 06:35 PM
vintageracer31
Ok thank you for your help
ol-blu
Mar 3, 2013 07:06 PM
Weberman3
Jan 16, 2012 08:27 PM
ChrisCarter
2004 - 2008 F150
Dec 4, 2011 09:35 AM
gamudslinger88
Jan 29, 2008 06:34 PM
pj'sbucket
Dec 14, 2003 03:13 PM
