Programmer/Tuner install
Old Sep 29, 2017 | 01:01 PM
Warrenedgar's Avatar
Warrenedgar
Will i gain much from a programmer/tuner on my 2011 6.7 liter? Truck is all stock now. Are there problems with running a tuner on stock truck.Should i do a Total delete?
Old Sep 29, 2017 | 01:27 PM
Braggs's Avatar
Braggs
Don't do it.
You can crank it all the way up until you blow a hole in the side of the motor, pop your head gaskets, or break a connecting rod. Delete if you want, but keep the tune stock or mild. See video below for reference.
Old Sep 29, 2017 | 09:03 PM
Sterling6.7's Avatar
Sterling6.7
So before the sky falls, you should read up on what it actually takes to knock a 6.7 down. The '11s had turbo and valve issues that were mostly resolved by the '12s and the '13s are even stronger. As always, the tuning has progressed with the experience of what damage can be done. Unless there is a pre-existing problem, you cannot window the block, blow head gaskets or break rods on a 6.7 when using the hottest tunes by the best known tuners out there coupled with the highest flowing intake. The fuel system and turbo just can't deliver more than ~540 HP (580 on '15-'17) and it takes close to 700 to really damage the bottom end. The reality is that if you tune it and beat on it, you have more risk of damaging the transmission. Call No Limit and ask them for options.
Old Sep 30, 2017 | 11:40 AM
UGA33's Avatar
UGA33
I could knock down 19 MPGs on 35" Toyo MTs with my 2012 running custom tuning. They will wake the trucks up for sure. 11-14s have limited air and fuel when compared to the 2015+ trucks.
The bottom ends of the 6.7 are weaker than previous PSDs, but with the limited air and fuel on the 11-14s, its takes some really bad tuning and a really stupid operator to hurt the engine. 480-500 is about all the 11-14 trucks are gonna push.
The turbos don't like to be spun up. Anything over 30psi is asking for trouble. They are a weak point on tuned 11-14 trucks. The transmissions are very strong on the 11-14 trucks. Wouldn't really worry about it if you are running good trans tuning. Have a buddy running a stock 6R putting down 700HP. Been doing this for the last 30-40k miles with a ton of track passes and dyno runs. Truck is at 100k miles and still going. He has a fully built bottom end with upgraded HPFP and turbo. Trans just won't die.
I say tune it and be happy
speakerfritz
6.4L Power Stroke Diesel
Dec 22, 2018 09:34 AM
oldsalt93
Jul 4, 2018 10:00 PM
tx_master_mason
6.7L Power Stroke Diesel
May 1, 2013 01:10 AM
APOLLO TROY
Jan 27, 2012 11:27 AM
Mitch1407
Jan 9, 2012 02:35 PM
