Light Up Platinum Sill Plates
So since Ford X'd the light up platinum sill plates for 2018, I am guessing a popular upgrade to 18's will be to buy the part number used in 17, and hopefully they are too lazy to change the harness and it would just be plug and play...
Anyone good with online Ford parts sites to find the part number and cost of the 2017 light up sills?
Thanks so much for pulling that apart to show me. I plugged in that part number (hc3b-2613201-ac) and it came up with nothing. Maybe the online retailers down drill down that far or something, kinda weird..
Hopefully they don't cancel replace the light up version with the non-light up version...
Josh
Josh
AND THERE IT WAS!!! The wiring harness is there (with a filler plug installed) for a perfect plug and play!
The reason you could not find the part number(s) online is because the pictures posted will only give you the engineering numbers and not the actual part number. So what I did, was found a VIN of a 2017 Platinum that had them, gave it to the parts guy and he looked up the truck parts/accessories by VIN and BOOM, below are the two part numbers, mine are already on order!
HC3Z2613209AA
HC3Z2613208AA
I am picking up my 2018 F250 Platinum from the dealer this afternoon/evening, but before we even finalized the deal, I secretly removed the sill to see.........
HC3Z2613209AA
HC3Z2613208AA
HC3Z2613209AA
HC3Z2613208AA
You are awesome, give us an update when you have it all done and its all working! I figured this was the case that it would be plug and play!!
BTW, those part numbers are those for Black sill plates?
