Light Up Platinum Sill Plates
So since Ford X'd the light up platinum sill plates for 2018, I am guessing a popular upgrade to 18's will be to buy the part number used in 17, and hopefully they are too lazy to change the harness and it would just be plug and play...
Anyone good with online Ford parts sites to find the part number and cost of the 2017 light up sills? |
They aren't available on the Platinum or Limited???
Sam |
I believe they are available on the limited.
Originally Posted by First Dually
(Post 17492763)
Originally Posted by jnuechte
(Post 17492779)
Yes they moved them to only available on the Limited.
My very loaded 2017 KR Ultimate F450 had a MSRP of $82,355. It's hard to imagine how they added $10K more stuff. |
Part numbers on sill plates, and harness location.https://cimg8.ibsrv.net/gimg/www.for...a19794a594.jpg
https://cimg0.ibsrv.net/gimg/www.for...09c9674662.jpg https://cimg7.ibsrv.net/gimg/www.for...6f766ac48b.jpg |
Thanks so much for pulling that apart to show me. I plugged in that part number (hc3b-2613201-ac) and it came up with nothing. Maybe the online retailers down drill down that far or something, kinda weird..
Hopefully they don't cancel replace the light up version with the non-light up version... Josh |
I was at the dealer today I could have asked them to look up the number.
ANY UPDATES ON BEING ABLE TO ORDER LUMMINATED SILL PLATES??
Originally Posted by Lumberman12
(Post 17517687)
(Post 17697720)
now that the 2018's are out anyone with a platinum pull off their door sills to check if the wiring harness is still there, or gone as far as buying the light up 2017 sills?
AND THERE IT WAS!!! The wiring harness is there (with a filler plug installed) for a perfect plug and play! The reason you could not find the part number(s) online is because the pictures posted will only give you the engineering numbers and not the actual part number. So what I did, was found a VIN of a 2017 Platinum that had them, gave it to the parts guy and he looked up the truck parts/accessories by VIN and BOOM, below are the two part numbers, mine are already on order! HC3Z2613209AA HC3Z2613208AA |
This forum just keeps costing more money every day.:-X22
Anyone have a picture of them in the dark? Are they all ricer'd out, or do they look classy?
Originally Posted by Tricon
(Post 17733252)
I can post a picture in a few days when they come in but on the ‘17 I saw they look classy and awesome! Huge compliment to the truck. |
Originally Posted by Jetsco
(Post 17732735)
I am picking up my 2018 F250 Platinum from the dealer this afternoon/evening, but before we even finalized the deal, I secretly removed the sill to see.........
AND THERE IT WAS!!! The wiring harness is there (with a filler plug installed) for a perfect plug and play! The reason you could not find the part number(s) online is because the pictures posted will only give you the engineering numbers and not the actual part number. So what I did, was found a VIN of a 2017 Platinum that had them, gave it to the parts guy and he looked up the truck parts/accessories by VIN and BOOM, below are the two part numbers, mine are already on order! HC3Z2613209AA HC3Z2613208AA You are awesome, give us an update when you have it all done and its all working! I figured this was the case that it would be plug and play!! BTW, those part numbers are those for Black sill plates? |
