Won't idle when warm.
Old Oct 3, 2017 | 09:53 PM
  #46
Tedster9's Avatar
Tedster9
Good videos. Hard to tell from here - in the first one though, the ignition timing sounds like it's off. The second one - what RPM? The gauge indicates according to the charts maybe intake leak, worn valve guides or sticky valve? But make sure ignition timing is set correctly and carb is adjusted right, I bet that will mimic other problems. Cylinder compression test check out OK?
Old Oct 3, 2017 | 09:58 PM
  #47
Jdusmc44's Avatar
Jdusmc44
I only had a little bit of time this evening and wanted to get the vacuum reading on video. Hopefully tomorrow I will check timing again and pull of the valve covers and take a look. I have never done a compression check but I'm not afraid to learn! I think I also definitely need to check sparks on each plug. Not sure if there is a misfire or if it's just associated with a leak somewhere.
Old Oct 3, 2017 | 11:11 PM
  #48
Jklnhyd's Avatar
Jklnhyd
A compression check is like rebuilding a carb is like learning there is no Santa. Once you know, the magic and hype is gone and you will wonder by you believed it was so ooo la la in the first place.
Old Oct 3, 2017 | 11:18 PM
  #49
Tedster9's Avatar
Tedster9
Pull all the plugs, block the throttle open, make sure the battery is full charged. It's really the first test before anything else. Evilbay has some pretty decent deals. It ain't Snap-On but I bought one for less than $20, quality isn't bad for the price. Accurate enough.
Old Oct 9, 2017 | 10:43 AM
  #50
Jdusmc44's Avatar
Jdusmc44
Finally did the compression test and all cylinders had a reading between 120-130. And each reached full compression with only a couple cranks. I'm thinking about doing a leak down test next. I hooked the vacuum gauge up again because in the last video I had the timing advanced. With timing set to 12*, idle set to 850 the vac gauge has a sweep reading between 10 and 14 in/hg.
Old Oct 9, 2017 | 11:18 AM
  #51
Jklnhyd's Avatar
Jklnhyd
Old Oct 9, 2017 | 11:22 AM
  #52
Jdusmc44's Avatar
Jdusmc44
Going g off the chart I would say burnt or sticky valves seems the most like what I see.
Old Oct 9, 2017 | 11:59 AM
  #53
1TonBasecamp's Avatar
1TonBasecamp
Strange that you would have that condition and still have some pretty good compression numbers though. Although I guess that's not impossible.
What was it reading with the timing advanced? And what was the timing at that point?
Since 12 degrees is actually a pretty nice setting for most engines, it's surprising (to me at least) that it ran good if it was anything more than say, 16 degrees BTDC. At that point my engine would have been pinging like a big dog under any acceleration.
If it ran better and had higher vacuum numbers (nearer to 18-21?) when the timing was more advanced, I wonder if the timing marks are off a bit.
Anyway, I'll re-read the last few pages to see what I missed.
Paul
Old Oct 9, 2017 | 08:21 PM
  #54
Jklnhyd's Avatar
Jklnhyd
Wouldnt be plug gap too close or points gap not synced?
Old Oct 10, 2017 | 10:58 AM
  #55
Tedster9's Avatar
Tedster9
Keep and maintain idle RPM around 550-650 and advance distributor for maximum steady manifold vacuum on the gauge. Should be 18" to 20" on a healthy stock motor. Lean out the carburetor mixture screws for maximum vacuum as well. May have to go back and forth a couple times as they interact with each other.
As a kind of verification test - then see what the timing is at indicated on the damper. It does sound a little like the marks might be buggered, tough to tell from here.
Old Oct 10, 2017 | 11:16 AM
  #56
Tedster9's Avatar
Tedster9
Did the engine spend a lot of time over the years sitting in a field inoperable or anything like that? Sludge and varnished fuel will tend to stick rings and valve lifters &c.
Replace 1qt of crankcase oil with Marvel's Mystery Oil. Install 4oz. of same for each 10 gallons of fuel in the gas tank. Both fuel and oil.
Then make a highway run or two, drive normally get it warmed up etc. It's a mild solvent with penetrating oil (wintergreen) and is just the stuff for freeing up valve lifters and stuck rings. Worth a try and usually works fast.
Old Oct 10, 2017 | 03:52 PM
  #57
Jdusmc44's Avatar
Jdusmc44
I have bee thinking of using seafoam or MMO. What is the best between the two and if you have used them, some say to let some through the brake booster vac into the intake? Is this common practice?
Old Oct 10, 2017 | 05:21 PM
  #58
1TonBasecamp
Originally Posted by Jdusmc44
I have bee thinking of using seafoam or MMO. What is the best between the two...
Never used either, but know many that have used both and I would have a hard time recommending one over the other just from reports.
But I'm still a big fan of cleaning additives even after using them for almost 50 years. Because for me at least, they've almost all worked as expected.
And the ones that did not could just have been due to the severity of the problem more than any lack of chemical prowess.
...and if you have used them, some say to let some through the brake booster vac into the intake? Is this common practice?
Unless you verify first that the booster line goes into the intake manifold in the carburetor plenum area, I would never use that hose. Since most that I'm familiar with go into some sort of vacuum tree that's screwed into only one intake runner, to only one cylinder, well, you can see where that thought is going.
You'll have one VERY clean cylinder!
It's probably one of the easier vacuum lines to access, but verify it's source.
Easier still would be the PCV vacuum line on any engine from the early sixties on up. They are all supposed to be plumbed to the common plenum, so are a better choice.
But just like the other one, verify it's source. Plenty of them out there that have been connected incorrectly.
Paul
Old Oct 10, 2017 | 06:01 PM
  #59
Jklnhyd's Avatar
Jklnhyd
I dont believe in seafoam, had 2 engines not start after dumping that stuff in em.
I use Type F ATF usually.
Old Oct 10, 2017 | 06:54 PM
  #60
Tedster9's Avatar
Tedster9
Don't pour it down the intake don't pour it down the spark plug holes don't suck it through a vacuum hose.
Just put it in the gas AND crankcase per the directions on the can. I've heard good things about Seafoam too, but I don't have any experience with that. I know for a fact MMO works for this purpose so mentioned it. If it doesn't work you're out 5 bucks, it can't hurt anything and may help.
