Looking for Any info for doing a cummins swap in my 1974 F250. Pros or cons on using the whole drive train from a 2000 Dodge Ram 2500. Or is there certain years dodge rams that are better to use then other. These are probably rookie questions, but I'll take any info I can. Thanks
Do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line?
It has a drop down search menu arrow, go to the "Advanced Search" option, top left side (search block) type in there what you are looking for and then go to the lower right column and highlight 73-79 forum. Select it and then you will have a detailed search just in the 73-79 forums.
