pitman arm reaming
Sep 26, 2017 | 11:23 AM
pitman arm reaming
Number Dummy
Is there a replacement for my pitman arm?
d2ta-3590-da I am having trouble finding the exact part number.
It is original to my 76 f350 2 wheel drive camper special.
If I was to get it reamed does anyone know the angle needed for the tapers?
Sep 26, 2017 | 03:51 PM
Quote:
Originally Posted by
1976F350campspecial
Number Dummy
D2TZ-3590-
D A
Look at the ID number cast onto the Pitman Arm to verify that it
is D2TA-DA
Sep 26, 2017 | 04:02 PM
Thanks ND.
I will get another look at it. I took about 4 pictures and the one I posted was the best.
it's definitely not 3590-DA like my post. My bad. It's 3590-FA. I am not 100% sure if the first two characters are D2.
Sep 26, 2017 | 04:12 PM
1976F350campspecial
Thanks ND.
it's definitely not 3590-DA like my post. My bad. It's 3590-FA . I am not 100% sure if the first two characters are D2.
D2TZ-3590-D .. Pitman Arm-Use with P/S / Marked with ID number:
D2TA-3590-FA / Obsolete
1971 F350 from serial number M00,001; 1972/79 F350 (except 1979 F350 4WD). All 1953/78 F350's are 2WD
1973/79 F250 2WD Crew Cab & 1974/79 F250 2WD Super Cab with 8,100 lbs. GVWR
Check your email.
Sep 26, 2017 | 04:46 PM
I confirmed the number is D2TA-3590-FA it is really a hard read. Is there a replacement for this obsolete number?
thanks
Sep 26, 2017 | 05:19 PM
1976F350campspecial
There is ONE available NOS
I mixed you up with FTE member 76f350spercamprspeal. I sent him an email with the only source.
Sep 26, 2017 | 05:23 PM
lol looks like i have a twin.
thanks again i will check into it.
Sep 26, 2017 | 05:35 PM
1976F350campspecial
The other member lives in MO .. he used to live here in SoCal.
I sent you a P/M with the source for the Pitman Arm
Sep 26, 2017 | 08:52 PM
Fords are tapered at 7.15°.
77flatbed
WTB - Parts & other
Jul 10, 2017 02:06 PM
bigcrunch
May 6, 2017 04:28 PM
ConnerSmith
Jan 4, 2015 07:12 PM
FLN
Jun 10, 2011 07:43 PM
dclary
Feb 4, 2009 04:28 AM
