12v cummins swap
Old 09-26-2017, 07:52 PM
1jeffm's Avatar
1jeffm
1jeffm is offline
12v cummins swap
Looking for Any info for doing a cummins swap in my 1974 F250. Pros or cons on using the whole drive train from a 2000 Dodge Ram 2500. Or is there certain years dodge rams that are better to use then other. These are probably rookie questions, but I'll take any info I can. Thanks
Old 09-26-2017, 08:31 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,365 Likes on 2,503 Posts
One of the best diesel swap threads out there. https://www.ford-trucks.com/forums/1...t=cummins+swap
Do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line?
It has a drop down search menu arrow, go to the "Advanced Search" option, top left side (search block) type in there what you are looking for and then go to the lower right column and highlight 73-79 forum. Select it and then you will have a detailed search just in the 73-79 forums.
CLVLNDLVR
09-23-2014 04:12 PM
rlewis581
1999 to 2016 Super Duty
67
01-09-2012 06:17 PM
mark460
34
01-13-2010 07:48 PM
1sscav
1978 - 1996 Big Bronco
07-09-2004 08:02 PM
Quick Reply: 12v cummins swap
