Over heating, collapsed hose.
Old Sep 26, 2017 | 04:18 PM
palmrose2's Avatar
palmrose2
Some of you told me last year that I really should run a fan. I haven't been. Over the course of the summer temps have been rising on my gauge from the reasonable temps I was initially running while moving. I installed a pair of ten inch fans and it barely made any difference. Today I installed a milodon high output water pump, the high capacity 180 degree thermostat that Tim sells, and another 10" fan. (I have room for 4). Also ran some sulfamic acid through the whole system beforehand.
I found that my correct Stant thermostat was working great as evidenced by the pan on the stove test. The OEM water pump looked fine. While up to temp, I brought the revs up to around 2,000 and witnessed the lower radiator hose collapsing. WTF? I'm thinking that was the biggest culprit the whole time.
The hose is made in Mexico and is labeled 60995, also 078. It is shaped and fits perfectly, but has no reinforcement or internal spring to resist collapsing. Do most of these rigs sport non collapsible hoses? Where could I find a coil to insert into the hose? Where could I find a shaped non collapsible hose. Any one else seen this?
Old Sep 27, 2017 | 10:09 AM
Aaron-71's Avatar
Aaron-71
Subscribed. Listening in for the answer. I recently bought a new formed lower & upper hose and I'm hoping I don't get the same issues.
Old Sep 28, 2017 | 04:32 PM
palmrose2's Avatar
palmrose2
Apparently when hot and system is pressurized, the collapse doesn't happen. After some research , I've learned that this is kind of a controversial subject. If everything's cool with my system, I don't think I'll bother with an internal spring.
I've cross posted this here cause this forum has so little traffic.
https://www.ford-trucks.com/forums/1...erheating.html
What this forum has is knowledge and a lack of fools.
Old Sep 28, 2017 | 04:48 PM
kopfenjager's Avatar
kopfenjager
true if your system is creating the 13psi the cap is supposed to hold, then the hose shouldn't collapse.
Old Sep 28, 2017 | 07:56 PM
ctubutis's Avatar
ctubutis
Yeah, I like it in here.
I get myself into trouble posting in the 73-79 forum, some personalities over there are just too much to deal with if I'm in the wrong mood.
Old Oct 10, 2017 | 09:39 AM
palmrose2's Avatar
palmrose2
So just now with a new 13 lb thermostat, the engine warm, and the upper hose hard and obviously under pressure, I had an assistant bring the revs up to 2500rpm and noticed the lower hose collapsing a little. Had him blip the throttle with the same results. I then got in the cab and blipped it perhaps a little more aggressively. The hosed collapsed completely. I checked the upper hose and found that the radiator was no longer under pressure. Does anybody know why?
palmrose2
24
Oct 20, 2017 06:20 PM
carprojects
May 4, 2010 10:17 PM
Reptar360
Feb 29, 2008 07:34 AM
9explorer8
Apr 22, 2007 11:38 AM
Kenworth
Oct 4, 2005 01:52 PM
