Low power
Old Sep 25, 2017 | 08:33 PM
tybeejoe's Avatar
tybeejoe
Low power
I recently purchased a 2005 F250 6.0 manual. It runs and starts great, however its slow where it bogs down when starting off. I just changed both fuel filters and the oil. I have a scangauge 2 and all the reading seem normal except MAP 42.3 and Barometric sensor reads nothing. I have triple checked the numbers in the scangauge and they are correct. When the baro is bad does it read nothing? Also no codes.
Old Sep 25, 2017 | 09:14 PM
FiznUKa's Avatar
FiznUKa
I'm assuming the reading is with KOEO? I would start with the MAP sensor. Remove it from the vehicle and check the nipple to see if it's clogged with soot. Then move onto the hose from the sensor to the manifold yeah just change it it's time. Then check the nipple into the manifold for soot.
Old Sep 25, 2017 | 09:26 PM
tybeejoe's Avatar
tybeejoe
Thank you for the quick reply. It read the same KOEO and KOER. I will check the MAP tomorrow.
Taylor815
17
May 19, 2017 09:32 PM
Deep South
Oct 1, 2014 01:32 PM
BranNinja
Jan 26, 2013 08:35 PM
03f3506.0
Sep 10, 2012 11:47 AM
edub32
25
Feb 20, 2009 05:51 PM
