dtc's
Old Sep 9, 2012 | 04:47 PM
03f3506.0's Avatar
03f3506.0
dtc's
Help.Dtc's 0238 and 2263 at the same time.Only 60,000 on my truck.What do they mean?
Old Sep 9, 2012 | 08:08 PM
Fordracing BII's Avatar
Fordracing BII
go here 6.0L Bible Table of Contents
Lots of good info including a Diagnostic trouble code chart
Good Luck
Old Sep 10, 2012 | 03:37 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Sep 10, 2012 | 04:25 AM
npccpartsman's Avatar
npccpartsman
Both codes point to a MAP sensor problem. Check the MAP hose and intake nipple for a restriction or plugging and clean the EBP sensor tube on the drivers side exhaust manifold. If the codes persist then replace the MAP sensor.
Old Sep 10, 2012 | 09:59 AM
Fordracing BII
A couple guys from Fort Smith couldn't steer you wrong.
Fort Smith, Montana
Fort Smith, Arkansas
Old Sep 10, 2012 | 11:39 AM
03f3506.0's Avatar
03f3506.0
dtc's
thank you for your help.I will heed your advice and go on from there.
Old Sep 10, 2012 | 11:47 AM
03f3506.0's Avatar
03f3506.0
Another question.I have a rcd egr delete and an oil cooler kit to install but I read so many different opinions on whether to do the delete or not.Is it better to get the cooler welded and reinstall it,replace the cooler,or just install the delete kit?Thank you much for your help.
Headviking
Mar 6, 2013 05:17 PM
adamzelazowski
18
May 30, 2009 04:22 PM
triskit16
Oct 27, 2008 09:59 PM
Benny2002
Jul 8, 2007 11:25 PM
99fordf350coding
Apr 22, 2007 10:42 AM
