Distributor rotor exploded!
Old Sep 25, 2017 | 05:52 PM
Thinlizzy13's Avatar
Thinlizzy13
On a 4 hour trip today my dizzy rotor decided it had lived a long enough life. In the first 30 mins of the trip the truck shuddered a bit going up hills, almost like it wasn't getting fuel, but then it cleared up. 1hr 30mins later I get a few pops out the tailpipe and the engine quits. Used my extra spark plug to figure out spark to dizzy, but none out.
Pop the rotor and see what is pictured below...luckily my wife was following me and a nearby store had a complete dizzy...
[url=https://postimages.org/][/url
I recently changed the rotor, cap, plugs, and wires (all motorcrft). What would have cause this?
Old Sep 25, 2017 | 06:00 PM
Conanski's Avatar
Conanski
Too much torque.
Looks like the rotor is burned in half, were you spooling that I6 like a V8 or something?
Old Sep 25, 2017 | 06:05 PM
Thinlizzy13
I wish I had some cool story, but I was going about 65 mph coasting down a hill lol
I typically drive like a grandpa
Old Sep 25, 2017 | 06:12 PM
Conanski's Avatar
Conanski
I got nothin.. that failure makes about as much sense as the flexplate failure I had last winter. You probably couldn't repeat that if you tried... luckily. Can't say I have even seen that happen before.
Old Sep 25, 2017 | 06:51 PM
Thinlizzy13
I guess I should've been keeping my extra rotor in the truck. I only bought a whole dizzy cause I wasn't sure if a haywire PIP would cause this.
Old Sep 25, 2017 | 07:10 PM
wtroger's Avatar
wtroger
I have seen this when the dizzy bushings get a lot of slop in them. Rotor catches stud on cap pow you are setting along side the road.
Old Sep 25, 2017 | 07:19 PM
Eddiec1564's Avatar
Eddiec1564
2X !! been there and done that!
Old Sep 25, 2017 | 08:34 PM
Mudsport96's Avatar
Mudsport96
It was about two years ago I pulled into my driveway and the truck let out a rocking backfire. After some investigation I found the locating tab on the dizzy had broken off and let the rotor slip. That was almost 60k miles ago and so far so good. It was odd for sure.
Old Sep 27, 2017 | 05:48 PM
F-250Flyer's Avatar
F-250Flyer
Looks like there was some serious arcing and melting going on inside the distributor. This can be caused by excessive coil wire resistance and or excessive spark plug gap, or perhaps a defective coil.
What does the old coil wire end look like? Was it burnt also?
Old Sep 27, 2017 | 06:02 PM
Tedster9's Avatar
Tedster9
It sez Motorcraft, but any chance it's not a genuine rotor but some ersatz made out of recycled milk jugs?
Old Sep 28, 2017 | 05:15 AM
Thinlizzy13
The new Napa Coil reads: primary- 1.2 ohms and secondaries 7500 ohms. I think primaries seem a tad high and the secondaries low.
No burning on the coil wire. Spark plug gap is still good- set to .044
Old Sep 28, 2017 | 07:24 AM
Tedster9's Avatar
Tedster9
Do basic or independent auto shops still have ignition analyzers or oscilliscopes? It would be real useful if somebody made a handheld (smartphone app?) that would show a trace or whatever, secondary voltage, duration, rise time in ms etc etc. High voltage does strange things when everything isn't setup right.
Old Sep 28, 2017 | 08:19 AM
Thinlizzy13
I hope not, I spent more than I would've liked for that rotor because of the name on it lol.
Old Sep 28, 2017 | 09:09 AM
Tedster9's Avatar
Tedster9
Well it does have that melty thing goin' on, that's why I asked.
Old Sep 28, 2017 | 10:35 AM
F-250Flyer's Avatar
F-250Flyer
OoO ! I was thinking you still had the old coil and wire. Those primary and secondary readings are within specs though. Too bad ya don't still have the old one.
