More power, need help!
Old Sep 24, 2017 | 11:13 PM
MadMax Project's Avatar
MadMax Project
I have a 1990 f150 with a 351w that has just over 300k on it and I'm wanting to get a little more power out of it to help tow and turn the 35x12.50 15lt tires, any suggestions? On a student budget so $1000-$2000.
Old Sep 25, 2017 | 07:59 AM
rswhitmore's Avatar
rswhitmore
Better Breathing
I am assuming the engine is in good mechanical condition, and can support a little more HP and Torque. 300K is a lot of miles. The best way to get more power from a factory Ford is to improve it's breathing. For the budget you are talking about, you should be able to buy a decent set of aftermarket aluminum heads with bigger valves and smaller combustion chambers (if you do the work yourself). This, along with a set of headers will make your Ford breath much better, and raise the compression, if you get smaller combustion chambers. I am sure there are other options, but this is where I would start.
Old Sep 25, 2017 | 05:24 PM
Conanski's Avatar
Conanski
What axle ratio does it have? Anything less than 4.10 is fighting an up hill battle you won't win. The next best upgrade after gears is a cam swap, new heads are almost a complete waste of money until the factory cam is changed... it really is that bad.
Old Sep 26, 2017 | 01:16 PM
Kemicalburns's Avatar
Kemicalburns
heck with 35's you should run at least 4.56 gears. motor upgrades will cost way more to get you moving in a decent manner.
screaminford
Apr 20, 2012 04:12 PM
graybird78
May 27, 2008 07:36 AM
Scot Clark
Apr 21, 2008 11:38 AM
crack
Dec 12, 2005 08:34 PM
scott9320
Jun 11, 2003 04:39 PM
