Emergency brake
Old Sep 25, 2017 | 05:08 PM
Rust Wrangler's Avatar
Rust Wrangler
They are expected soon at Mid Fifty. Might give them a call as well.
Link: 1939-56 Ford F-100 Park Brake Handle Clevis, Cable To Handle - 91A-2484
Old Sep 25, 2017 | 06:03 PM
Gigemags05's Avatar
Gigemags05
Chucks Trucks found me one. That was fast. Awsome
service.
Thanks again for the link!!
Old Sep 25, 2017 | 06:49 PM
Rickster800's Avatar
Rickster800
Great you were able to get one! You are welcome for the help. That's what I enjoy about FTE, there are a lot of great members helping each other.
Old Sep 26, 2017 | 08:51 AM
GB SISSON's Avatar
GB SISSON
I need some parts for my brake cable assembly on my toner pu. I googled clevis fork and found midwest control products. Lots of sizes and materials and more threads than the reproduction one shown.
Old Sep 26, 2017 | 09:06 AM
FireEngineMike's Avatar
FireEngineMike
SouthsideObsolete.com Call to ask Fred if he has any.
Old Feb 1, 2018 | 07:35 PM
Gigemags05's Avatar
Gigemags05
Originally Posted by Rust Wrangler
I used the truck's factory hand lever assembly and cable. I flipped the Explorer emergency brake cable assembly over on the rear end so it's actuating cable is now on the passenger side. This lines it up with the trucks factory cable. I then grafted both cables together using clamps and a turnbuckle for adjustment. The clevis at the hand lever is still adjustable but isn't needed, as adjustment is now done at the turnbuckle under the truck. I have the disc brake rear end so it was easy to simply reconfigure it to the right side using the Explorer cable assembly and fabbing up a new anchor bracket to the frame.
91A-2484 is the part number for the proper clevis. Dennis Carpenter has them available.
Hope this helps.
i need to find a cable to go from the hand brake to the turn buckle. All i can find online is “rear” parking brake cables. Is there somewhere that sells the front part of the assembly?
Old Feb 1, 2018 | 07:54 PM
newold46's Avatar
newold46
Out of stock.
Old Feb 2, 2018 | 01:05 AM
Rickster800
Check out this thread:
https://www.ford-trucks.com/forums/1...c-2-ton-3.html
I listed the parts and suppliers for emergency brake parts including the cable you are inquiring about. Hope this helps
Old Feb 2, 2018 | 08:10 AM
Padilla Shore's Avatar
Padilla Shore
I needed the front cable for my tonner last year. Fred at Southside Obsolete had an NOS available---he may have the one you need. His number is 507-332-6789.
jakevidrine
Jan 20, 2018 10:17 AM
highboyhouston
Apr 21, 2015 11:03 PM
wyckedcombo17
Apr 20, 2011 11:31 PM
fishslab
Large Truck
Feb 18, 2010 12:12 PM
Casey88
Sep 2, 2008 12:12 PM
