Sponsored by: Real Truck
No CAN Serial Bus communication
Old Sep 23, 2017 | 04:00 PM
Chester_field's Avatar
Chester_field
I have and 2008 f 250 super duty. I had to change the coolant recovery bottle today. Taking the battery out the wrench shorted across the battery. **** happens!
Now I have no PCM communication no ABS communication no TCM communication and few others. What problem is I have no CAN serial bus communication and I need a wiring diagram to diagnosis it. I've checked the fuses and tested the relays all test good. It's easy to talk about what I can communicate with Instrument cluster is all i have that will respond.
The one schem I did find I can't enlarge it or print it and he hand drew on it so I can't really read what I need to. The Haynes manual I bought too, should have said we have some diagrams, the one you really want isn't in here.
Anybody have one I can print?
Thanks in advance
Old Sep 24, 2017 | 10:09 AM
Chester_field
Thanks in advance
Update I've checked voltage on CAN-H and CAN-L both are within spec, also I have checked the resistance across both and that is with in spec. Also the voltage on my DLC is a little low (11.8V) but that should be normal given the amount I've had the key on and not running. So without a wiring diagram I am not sure where to start looking, if it is fused in a different location then Power distributions boxes.
What I do know is I have no bare wires to ground.
artopium mike
Feb 14, 2013 05:05 AM
SonofaFord
25
Aug 13, 2010 10:53 PM
86F150Riggins
19
Jun 7, 2007 12:26 PM
74fordtruck
Apr 25, 2005 07:53 AM
musmly65
Jul 18, 2002 09:47 PM
