vacuum pump replace
Old Sep 20, 2017 | 12:40 PM
john321's Avatar
john321
vacuum pump replace
Brakes went out on 1997 f350 7.3. Replaced vacuum pump and now brakes work. On restart truck barely runs with check engine light. It ran fine before pump was replaced. Does the computer have to be reset after new pump installed?
Old Sep 20, 2017 | 06:10 PM
Kingkong0192's Avatar
Kingkong0192
No.
You have another issue.
Old Sep 20, 2017 | 06:34 PM
Red97350's Avatar
Red97350
Is there anything else you moved/ messed with when you replaced the vacuum pump?
Red
Old Sep 21, 2017 | 01:12 PM
john321's Avatar
john321
No there was nothing else touched except removing the belt. I worried about it all day. You might not believe this but GOD told me to unhook the batteries. Left them unhooked all night. Hooked them back this morning and truck runs perfect. I'm not much of a mechanic so I don't know why that would work, but it did. Thank y'all for your input, you have greatly helped me with this truck before.
Old Sep 22, 2017 | 08:14 AM
oldbird1965's Avatar
oldbird1965
To me that means you had a trouble code that go cleared (reset) with the batteries being disconnected.
Old Sep 22, 2017 | 03:38 PM
john321's Avatar
john321
Thanks for the input. I appreciate this forum. It's helped me more than once.
Bob_T
26
Apr 12, 2017 03:06 PM
62uni4x4
Sep 15, 2011 12:52 PM
Jaaaaaaackman
Apr 1, 2010 08:57 AM
red97stroker
Feb 12, 2010 07:37 PM
duck fan
26
Nov 20, 2009 01:29 PM
