Door "stuff"
Old Nov 16, 2017 | 08:10 PM
abe's Avatar
abe
Here is what the clip looks like.
I see you have the tool now.
Old Nov 17, 2017 | 08:55 AM
1953FlatJohn's Avatar
1953FlatJohn
Yes sir have the tool. It helped some. I used it to compress the bezel behind the window crank downward several times, must have cleared some debris under the crank. But the tool did not remove/push the clip out. But it made more room. Used a pair of electric pilers with plastic coating. Turned them upside down and pressed down on the bezel from two sides. Then Used a metal dentist tooth pic to fish out the c clip far enough to pull it out.
Took about two minutes to get the window crank off. Big fingers you know. The door latch is another case, as the wire clip is mashed up pretty bad, so no easy corner to grab. More time required for that. About the tool. I don't thing it is the right one for 1953 truck cab. In the service manual (for a 1953 truck) there is a tool with three prongs in a photo. Looks different then the tool I was able to find at parts store or the Internet.
If anyone has the proper 1953 tool and uses it successfully I would like to hear your story. Sorry GoldCo didn't mean to run away with your thread, but maybe you will find this of some help if you have to take another door apart. Thanks
Old Nov 17, 2017 | 08:09 PM
GoldCo's Avatar
GoldCo
try again
...so, any thoughts on best way to proceed? install latch mechanism first, then window regulator, then lock, then rattle kit, then glass (and does it matter vent or door glass first)??
DisneysPatB
Nov 22, 2017 06:43 AM
hutchie
52
Apr 5, 2017 12:01 PM
fordman75
Jun 9, 2014 09:21 AM
deyomatic
Oct 27, 2008 06:42 PM
