Aerostar Ford Aerostar
Transmission type and shift kit?
Old Sep 9, 2003 | 07:47 AM
agelder's Avatar
agelder
Question Transmission type and shift kit?
It's getting time for me to drop the pan on the Aerostar and change out the filter, but I'm not sure what kind of transmission we have (93 3.0 shorty RWD). I figured while I was digging around I would put in a shift kit if one is available. Anyone know of one?
Old Sep 9, 2003 | 10:33 AM
aerocolorado's Avatar
aerocolorado
All Aerostars use the A4LD transmission, however there are different versions for 3.0 vs 4.0, short vs extended, etc. The differences are in the internal components. They all share the same case.
As to shift kits, I don't have any experience with these.
Old Sep 9, 2003 | 12:20 PM
agelder's Avatar
agelder
Figures. I love it when the same transmission comes in many different varieties. Thanks for the A4LD info though, it's a good starting place.
Edit: I found out there is a mild shift-kit available from transgo, but you have to install during a rebuild, so it won't be going in anytime soon.
Old Sep 11, 2003 | 11:10 AM
TallPaul's Avatar
TallPaul
I am thinking shift kit for my wife's '92 3.0 shorty aero. B&M makes one that hooks up externally so you don't have to drop the pan. I might go with that or have my mechanic install the Transgo kit next time we change the fluid (won't be for a couple years). I hate the way this tranny won't stay in the gear you want. Double downshifts. Down, up, down. Up, down, up. All kinds of strange shifting. Funny thing is my wife says it never happens to her.
Old Sep 11, 2003 | 01:31 PM
agelder's Avatar
agelder
B&M Makes one? How much? I'm interested
Old Sep 11, 2003 | 01:54 PM
TallPaul's Avatar
TallPaul
I saw it in either the JEGS or SUMMIT RACING catalog for the A4LD (or whatever the aerostar one is) tranny and it was somewhere around $60. I think it is electronic and has three settings: stock, street, and strip. You could find JEGS or SUMMIT on the net. Not sure how well it works, but expect the valve body kits are a bit nicer. Still the three settings could be fun.
Old Sep 11, 2003 | 03:02 PM
agelder's Avatar
agelder
Interesting... very interesting....
Old Sep 12, 2003 | 06:25 AM
TallPaul's Avatar
TallPaul
It is JEGS and it is called the Shiftplus Electronic Shift Improver. It has three levels--stock, firmer, much firmer--which you can switch between anytime. Says good for performance, towing, and RV. JEGS catalog number 130-70383 for GM(some number) and Ford A4LD @ only $42.99.
I put an electronic shift improver on my motorhome, but it dosen't have a controller. It was about $250 from Bankspower.com It did make the shifts fast and firm under load.
I am thinking about getting this B&M (can barely make out the B&M on the part in the JEGS catalog) shift improver for my wife's Aerostar, which has 98,000 miles on it. If anybody does it, let us know how it works out, how easy to hook up, and how you like te performance.
Frankly I am a stick shift guy and if stuck with the automatic in the Aerostar would be tempted to convert it to manual valve body with a floor shifter, but there is only so much you can do the the wife's van.
Old Sep 12, 2003 | 07:36 AM
agelder's Avatar
agelder
I'm very leery of those electric improvers, I've occasionally heard bad things abou them.
razor_jim
Aerostar
35
Mar 9, 2017 03:17 PM
flowney
Aerostar
Oct 28, 2015 05:20 PM
blackeyed1
Aerostar
Jul 30, 2014 02:54 PM
fastestmom1960
Aerostar
Oct 24, 2004 09:22 PM
BullHawk
Aerostar
Jan 31, 2004 09:52 PM
