Bulbs in instrument cluster
Old Sep 19, 2017 | 08:39 AM
Stevaroo01's Avatar
Stevaroo01
Does anyone know how many bulbs there are total behind the instrument panel? Including blinkers, dummy lights, and instrument back lighting. I'll be adding a tach to my cluster and I need to replace a few bulbs as well. So I'm thinking I'll just switch everything over to LED while I'll have the instrument cluster out anyway.
Thanks in advance!
Old Sep 19, 2017 | 09:28 AM
R&RFord's Avatar
R&RFord
Just had mine open and it had 17 I believe.
Number will vary on equipment and year model.
Old Sep 19, 2017 | 12:29 PM
EllieMae94's Avatar
EllieMae94
Mine out of a '94 has 17
Old Sep 19, 2017 | 02:54 PM
Dean06919's Avatar
Dean06919
94 and 97 with and without tachs take 17, bulb 194. Keep it simple, just put the original bulb back in and be done with it.
Old Sep 19, 2017 | 03:48 PM
bill-d-c's Avatar
bill-d-c
I have a 93, what does it take to get to the bulbs? I have a few out myself.
Old Sep 19, 2017 | 04:20 PM
Dean06919's Avatar
Dean06919
Thanks in advance!
Can't add a tachometer, you need a complete instrument cluster with one. Follow this grouping by year: 92-93, 94-95, 96-97. For example, if your truck is a 93, only 92 and 93 clusters are plug and play.
Old Sep 19, 2017 | 09:44 PM
Stevaroo01's Avatar
Stevaroo01
Thank you! This is exactly what I needed to know!
Old Sep 19, 2017 | 09:46 PM
Stevaroo01's Avatar
Stevaroo01
Thank you! I guess I used the wrong terminology. I am putting in a tach instrument cluster and will be putting my speedo into it so I maintain correct mileage. Going to replace backlights while I have the cluster out.
Old Sep 19, 2017 | 10:43 PM
mrollings53's Avatar
mrollings53
The bulbs insert into little black sockets that twist into the back of the cluster. Turn them counterclockwise about a 1/4 turn then pull the socket out.
Old Sep 19, 2017 | 10:48 PM
mrollings53
Remove the bezel around the instrument cluster. The two horizontal trim pieces pop out, and there are torx screws behind them. The rest of the dash bezel pops off. Disconnect the fuel tank switch, and 4x4 switch if you have them. Unscrew the black (I think, there should be gold ones too that hold the cluster together) torx screws, then pull the cluster out. It's a tight fit out of the dash. You should be able to replace bulbs without disconnecting the wiring harnesses.
Old Sep 20, 2017 | 07:50 AM
bill-d-c's Avatar
bill-d-c
Thanks for the info, I appreciate it.
Old Sep 20, 2017 | 07:33 PM
adam.hilberath's Avatar
adam.hilberath
Thanks in advance!
i didnt do all the lights like that in mine, i did all the illum. Lights in LED. I will say, if you are doung any colors (red,blue, anything but green) take the clear cover off of your gauges and a q tip with nail polish remover. Rub very lightly and then quickly clean it off. I had a papertowel and a q tip soaked in water. Otherwise it eats into the plastic. You do it right all will be bright n clear. Dont use cheap ebay leds. They suck. I have them in mine and i always have 1 out. As for numbers, get roughly 20. If you pull your climatr control panel you can do those too. 3 i think in that. All 194 bulbs.
Old Sep 20, 2017 | 08:46 PM
Stevaroo01's Avatar
Stevaroo01
Thanks! I will be doing the climate control panel too. Ultimately, I’ll switch all interior lights to LED.
countrycar
Dec 7, 2016 11:39 PM
dcchadwick
Sep 13, 2016 07:56 PM
casanezo
May 8, 2011 02:54 PM
sammy77
Sep 6, 2010 05:38 AM
Jack01
Oct 3, 2003 05:45 PM
