replacing the ac compressor only?
Old Sep 18, 2017 | 10:02 PM
bballcrf's Avatar
bballcrf
my system works great, will get down to 38-40, compressor sounds fine but is leaking behind the clutch area, getting freon all over, tomorrow im putting a new motorcraft compressor on, my question is since everything is working and no noises, will i be fine just doing the compressor? ive heard alot of talk about accumulator, orifice tube, condensor replacement but mostly just from posts where the compressor grenaded. thx
Old Sep 19, 2017 | 08:33 AM
farmert's Avatar
farmert
You should replace the accumulator/drier any time the system is opened up. Be sure to pull a vacuum on it, to remove the air from the system, before adding the freon.
Old Sep 19, 2017 | 10:26 AM
bballcrf's Avatar
bballcrf
i replaced the manifold line off the compressor last week, had it vacuumed down, filled, and works great since, but didnt know the compressor is also leaking, so its already been open and still cools great, ive never messed with ac so its a can o worms type of thing
jake22si
1997 - 2003 F150
Jun 28, 2015 09:04 AM
TheKirbyMan
Sep 18, 2010 10:01 PM
TheRobIdentity
Aerostar
Aug 5, 2006 04:30 AM
fcarruth
1978 - 1996 Big Bronco
Jul 19, 2003 01:12 AM
Katt
Apr 14, 2000 07:25 PM
