Aerostar Ford Aerostar
Air compressor toast?
Old Aug 4, 2006 | 10:16 PM
TheRobIdentity's Avatar
TheRobIdentity
First off, I know basically nothing about cars.
Now, my A/C has been non-functional for some time. The 'vent' works, and I can get Normal/Max A/C to run if the engine is off (though it doesn't feel much different) - however, if the engine is running, the A/C and defrost are no-go. They will run, but there is a high-pitched screeching noise from the engine when they are on. I have been told that it is most likely a ball-bearing in the air-compressor. Dealer says they'll have to replace the unit, at a cost of roughly $900. There is no way I will have that kind of money any time soon. Is there any way that I would be able to get the part and install it myself, or would I be better off getting a mechanic to do it w/ my lack of knowledge/experience?
Thanks!
[94 Aerostar]
Old Aug 5, 2006 | 12:20 AM
copper_90680's Avatar
copper_90680
Hi Rob:
Welcome to our FTE forum.
Old Aug 5, 2006 | 01:08 AM
xlt4wd90's Avatar
xlt4wd90
Rob,
It sounds like a jammed AC compressor. Does the engine slow down or attempt to stall when this happens? Right now, just the belt is slipping, but it will get worse.
Unless you actually know how to repair the compressor, the only solution is to replace it. This will require pulling the refrigerant from the AC system first. Then you can liesurely replace the compressor with either a rebuilt or one that you pull from a salvage yard. Then the system has to be evacuated and then refilled with refrigerant.
The first and last parts will have to be done by an AC mechanic. But you can do the hard work of replacing the compressor, and save yourself a bunch of money.
Old Aug 5, 2006 | 02:38 AM
Pablo-UA's Avatar
Pablo-UA
Rob, if you have time and insperation, you can replace A/C compressor... here, in Ukraine I can bue refrigerant in small baloons and fill the system by myself, but as practice shows, mechanics check A/C for leakages better, then me, and as result, to fill it in the shop may be cheapper. So to save some mony there is a reason to replace compressor by yourself, but no reason to fill it in garage....
and I dont advice to you to rebuild jammed compressor.... leakeages are possible, and no reason to use compressor from junkyard, exept of compressor fromm new wrecked car. Ones I found nearly new a/c compressor made by Valeo for $50.... I've installed into my friend's car... really interesting compressor: small crankshaft and 8 pist. inside...
Old Aug 5, 2006 | 04:30 AM
96_4wdr's Avatar
96_4wdr
Hi Rob,
leak detection is easy and low cost
DIY A/C info Click
have to do a complete flush, replace accumulator/dryer and orfice tubes
find a compressor from a wrecked rig
dealer installed and factory installed a/c use different compressors
Ready-Aire Compressor:
Part Number: 2039
This product fits the following vehicles - click on a vehicle to see detailed engine information.
FORD back to top
1991 - 1997 AEROSTAR
1999 - 2002 F-350 SUPER DUTY PICKUP
1991 - 1996 BRONCO
1990 - 1997 F-450 SUPER DUTY PICKUP
1996 - 2000 E SUPER DUTY
1999 - 2002 F-450 SUPER DUTY PICKUP
1994 - 1996 E-150 ECONOLINE
1999 - 2002 F-550 SUPER DUTY PICKUP
1994 - 1996 E-250 ECONOLINE
1994 - 1997 F53 STRIPPED CHASSIS
1992 - 2001 E-350 ECONOLINE
1992 - 1996 F59 STRIPPED CHASSIS
2000 - 2003 EXCURSION
1994 - 2005 MUSTANG
1991 - 2003 EXPLORER
1991 - 2005 RANGER
2001 - 2005 EXPLORER SPORT TRAC
1993 - 1995 TAURUS
1991 - 1996 F-150 PICKUP
1992 - 1994 TEMPO
1990 - 1997 F-250 PICKUP
1991 - 1997 THUNDERBIRD
1999 - 2002 F-250 SUPER DUTY PICKUP
1995 - 2003 WINDSTAR
1990 - 1997 F-350 PICKUP
LINCOLN back to top
1993 - 1994 CONTINENTAL
MAZDA back to top
1991 - 1993 B2200
1994 - 1996 B3000
1994 - 1997 B2300
1998 - 2005 B3000
2001 - 2005 B2300
1994 - 2005 B4000
1998 - 2001 B2500
1991 - 1994 NAVAJO
1991 - 1993 B2600
MERCURY back to top
1991 - 1997 COUGAR
1992 - 1994 TOPAZ
1997 - 2001 MOUNTAINEER
1993 - 2002 VILLAGER
1993 - 1995 SABLE
NISSAN back to top
1993 - 2002 QUEST
AggieOutlaw
May 19, 2015 02:26 PM
97ExpGuy
Jun 24, 2014 07:01 PM
duck94
Mar 2, 2011 08:15 AM
Opossum
Nov 9, 2008 01:19 PM
Tony1974
Jun 14, 2005 09:48 AM
