Neutral safety switch failure/disable?
Old Sep 17, 2017 | 08:00 PM
bluefeather300's Avatar
bluefeather300
97 cclbdrw zf5 - my truck has failed to start/turn over a few times now without attempting to push the clutch in multiple times or very hard. I am assuming this is the neutral safety switch causing me issues. Is there an easy way to disable this before I replace it so I don't get stranded and/or does anyone have anything else I should check?
Old Sep 17, 2017 | 08:22 PM
Kingkong0192's Avatar
Kingkong0192
You can unplug it and jump the pins to disable it.
do a search on which to jump as I don't remember.
Old Sep 17, 2017 | 08:44 PM
bluefeather300
I did some searching before posting and came up with nothing. Could be because I'm in my phone and is kinda being a PITA
Old Sep 18, 2017 | 03:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like the clutch pedal bushing is wearing out and needs replacing. this will cause the clutch interrupter switch to no work unless you really stomp on the pedal.
i would fix it instead of bypassing the switch, because the next step is the clutch not completely disengaging.
Old Sep 18, 2017 | 08:57 AM
madpogue's Avatar
madpogue
^^^^^ This may already be happening. Either the bushing at the pushrod or the pedal box bushings, or poss. both. This can cause a bit of clutch engagement that may not be noticed by the vehicle moving, but can still cause added wear. Esp. if the problem has manifested by it taking more and more pedal effort to get the switch to engage, that's a sign of wear, rather than of a bad switch.
To the OP, if you were searching on "neutral safety", that's why you didn't find anything. Switch has nothing to do with being in neutral; a search on "clutch safety switch" or "clutch start switch" should turn up results.
Old Sep 18, 2017 | 09:11 AM
knottyrope's Avatar
knottyrope
if your brake pedal moves when pressing the clutch, then the pedal bushings need to be replaced
Old Sep 19, 2017 | 12:06 PM
bluefeather300
Brake pedal has sone movement with the clutch pedal - looks like bushings for me - thanks for the help guys - I'll do some searching for bushing and replacment procedure
Old Sep 19, 2017 | 12:40 PM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...nfo-links.html
has a buck of mod and tech advice
Jayme Duty
Feb 21, 2011 02:58 PM
oh2bnok
1983 - 2012 Ranger & B-Series
May 4, 2010 01:39 AM
bigreddieselco
Mar 8, 2009 05:05 PM
RustyFord88
May 23, 2007 12:25 PM
Kool Bronco
1978 - 1996 Big Bronco
Aug 18, 2003 05:05 PM
