4x4 and low range indicator lights backwards
Old Sep 17, 2017 | 11:21 PM
TCBdrive's Avatar
TCBdrive
Recently picked up a 96 f250, manual trans, 4407 transfer case (manual shift) to haul some off-road toys. The low range light comes on in 4 wheel, and when shifted into low the 4x4 light comes on.
previous owner did a little hacking here and there i had to fix but havent pinned down this one. Any quick ideas of where to look?
Old Sep 18, 2017 | 07:21 PM
Red97350's Avatar
Red97350
I'm thinking that there may be an issue with the switch on the transfer case.
Red
Old Sep 18, 2017 | 10:38 PM
jason90f150's Avatar
jason90f150
Make sure there is a washer between the sensor and the case
Old Sep 18, 2017 | 11:27 PM
TCBdrive's Avatar
TCBdrive
Will do on the washer. I have plenty of sizes of aluminim drain / fill plug washers. Some reason i was thinking there was just an O-ring so ill see what it does.
am i right to assume the two wires to the switch, one is for each lamp?
Old Sep 18, 2017 | 11:31 PM
jason90f150
The washer is more like a calibrated shim. I think it's a continuity switch one for H and one for 4Low.
Old Sep 18, 2017 | 11:34 PM
TCBdrive's Avatar
TCBdrive
Ok well ill try some different thickness washers i have. And see if any straighten it out. Not really a big deal but sometimes the simple things drive me nuts.
Old Sep 19, 2017 | 12:06 AM
TCBdrive's Avatar
TCBdrive
So before i get too in depth here, i found a plug farther up the harness that had a glob of silicone, and it turns out someone had the two switch wires reversed. Un-pinned them and fixed it right, now 4x4 is on in 4 hi and 4x4 and low range lights on in low.
i recently rebuilt the transfer case and somehow overlooked that hacked up plug.
Either way thanks for the pointers.
87thhunter
Jul 14, 2014 04:21 PM
Biscayne
Offroad & 4x4
May 12, 2012 03:12 PM
toolman
1978 - 1996 Big Bronco
Nov 24, 2010 10:45 PM
dyhrdford
Sep 23, 2009 10:35 AM
jayrus
Jun 23, 2003 07:10 PM
