1978 - 1996 Big Bronco
Transfer case plugs
Old Nov 23, 2010 | 01:29 PM
toolman's Avatar
toolman
Transfer case plugs
So....I most recently learned I may have plugged something in wrong when I reinstalled my tranny and transfer case. I do not know exactly which transfer case I have but it's in a '90 Bronco with a 5.8 and an E4OD. It's fully manual, and front to back on the shift lever it goes 2h-4h-N-4L What's happening is the Low Range light comes on in 4h instead of the 4x4 light, and both lights come on in 4L. This leads me to believe that I got two plug reversed. What I don't know, is where the plug(s) is/are located on the case. Hopefully I've posted enough info for someone to help me ID my transfer case. Any advice is appreciated !!!
Thanks !!!
-Scott
Old Nov 24, 2010 | 01:24 AM
g_k50's Avatar
g_k50
My bronco lights up the same way. low range is lit when in 4H and 4X4 and low range are lit when in 4L.
1990, 5.0L, AOD, BW1356 manual shift.
Old Nov 24, 2010 | 09:23 PM
helirich's Avatar
helirich
Is it possible to switch the wires at the dash?
Old Nov 24, 2010 | 10:45 PM
toolman's Avatar
toolman
I don't *think* I can...but while that would solve the indicator problem, but it would not address the E4OD shift problem encountered when the TCU thinks I'm in low range and I'm not.
