Problems with Eagle Eye headlights
Old Sep 19, 2017 | 07:57 AM
ITSOT's Avatar
ITSOT
Wow. It's been busy while I was busy. Thanks for the great information!
I did some Googling, and I think I may be able to tinker with the wiring harness that came with the Eagle Eyes. I hope the fix is this easy!
Thanks again for all your information.
Old Sep 20, 2017 | 07:38 AM
ITSOT's Avatar
ITSOT
Well, it was only a bent pin!
I haven't taken the time to learn which pin is the ground, etc.; but, the middle pin on the light bulb itself was bent up just so (about 20º) that, while it would still enter the connector, it would miss the contact in the connector.
The lesson is: Don't get all bent out of shape!
Thanks for all the replies. If I ever need to replace these Eagle Eyes, I'll come back to this thread for my options!
Old Sep 21, 2017 | 07:02 PM
mojakus's Avatar
mojakus
Originally Posted by andym
I'd give those tires a real close inspection. They haven't been made in several years now and they are probably past their best-before date. I replaced a set of those with KO2s last year because the sidewalls were cracked and dried out.
I did the exact same thing recently. Bought a truck with these same older model tires on it. Once they came off, you could see some pretty extreme fissures on the sidewall
Old Sep 22, 2017 | 07:55 PM
andym's Avatar
andym
Smart money is in tires and brakes.
I should add that the KOs that were taken off had about 70% of the tread remaining. But the cracks in the sidewalls...
Old Oct 13, 2017 | 10:09 PM
travs66's Avatar
travs66
Originally Posted by ITSOT
Second, when I switch from low to high beam, the passenger's side beam(s) functions properly — the beam raises to point farther down the road, as one would expect the high beam to do. However, with the driver's side beam, when switching from low to high beam, the high beam points lower in the road, closer to the truck — like it is aimed at 10 feet in front of the truck (while the low beam is aimed at, maybe, 50 feet in front of the truck; I think you get the idea). This characteristic stays the same when I make vertical adjustments on this side.
I too have this same issue. The po put 07 HD lights, or their knock offs, in before I bought it. Glad to know I'm not the only one.
Old Oct 14, 2017 | 07:22 AM
ITSOT's Avatar
ITSOT
Did you see that the problem, in my case, was only a bent pin? Look two or three posts above yours. And, good luck. (Talk about an annoying problem!)
Old Oct 14, 2017 | 06:08 PM
travs66's Avatar
travs66
I missed that last night! I’ll look at mine to see if that is my issue. Thanks!
Old Mar 21, 2018 | 10:21 AM
530ktmpilot's Avatar
530ktmpilot
Old thread I know but just wanted to add my experience recently installing a set of eagle eyes on my 2006. Fit perfect and adjusted easily. Everything is plug and play regarding the wiring connectors. I added silverstar ultra bulbs and lighting is much improved. Beam pattern and coverage is similar to the OEM as well as the quality of construction. Haven’t had them long enough to determine if the lenses will turn yellow over time but a big improvement over the current OEMs as the lenses were yellowing badly and had micro cracks all throughout the lens which made them pretty dim even on highbeam. As an fyi, ford’s only have a vertical adjustment on the 2005-2007 models and these function similarly. Left to right was fine as is but would be nice to have that adjustment just in case.
Old Mar 21, 2018 | 07:32 PM
Tbug05LTD's Avatar
Tbug05LTD
I bought a pair of these black backed ones from Amazon and I have the same issues as the OP except it's with both lights. The lights are a brighter white when swithing to high beam but project
lower.
Old Mar 21, 2018 | 07:34 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
so factory heads only let you install the bulb in 1 direction. since you are seeing them both point down on high beam, I'd put money on them being upside down
check your bulbs, and try to install them 180 out. the LED bulbs I have installed in the headlights right now had to be oriented as well.
Old Mar 22, 2018 | 12:30 AM
Tbug05LTD's Avatar
Tbug05LTD
Tylus, thanks for the info. I'll give that a try this weekend.
delorenzomp
Sep 23, 2018 06:11 AM
Skydivelout
Jan 27, 2018 07:09 PM
DeadFife
Apr 28, 2017 07:12 PM
jnmescape2010
Escape & Escape Hybrid
Dec 23, 2014 07:26 AM
andyman91
Dec 21, 2009 12:42 PM
