Sponsored by: Real Truck
Low beams do not work!!! Need Help!!
Old Apr 28, 2017 | 05:01 PM
DeadFife's Avatar
DeadFife
Howdy y'all new member here. I am in need of some help. I have bought here recently a 1999 F250 Superduty 4x4 with the 7.3l and my problem is my low beam headlights do not work. My high beams and park lights work but low beams do not. I have replaced the MFS and have checked all fuses and wiring and everything checks out. I can not for the life of me find any diagrams on this truck. I have power coming off of my headlight switch and going into the MFS but I do not have power coming out on the low beam circuit. Am I missing something. Really frustrated right now and I can't drive the truck or get plates on it. Also when I flip onto high beam both low beam circuit and high beam circuit coming out of the MFS light up. Needing help!!!
Old Apr 28, 2017 | 05:42 PM
seville009's Avatar
seville009
Dumb question, but are there separate bulbs for high and low beam? If so, maybe the low beam bulbs are burned out.
Old Apr 28, 2017 | 06:11 PM
DeadFife's Avatar
DeadFife
No no seperate bulbs they're all in one and they are new
Old Apr 28, 2017 | 06:20 PM
seville009's Avatar
seville009
The only simple thing that I can think of to check are the bulbs themselves. Mske sure they're the correct oem bulbs (maybe the prior owner put in replacements?)
Old Apr 28, 2017 | 06:33 PM
DeadFife's Avatar
DeadFife
Bulbs are brand new didn't make a difference, plus I don't have power coming out of the brand new MFS when you turn on the headlights unless you turn on brights
Old Apr 28, 2017 | 06:36 PM
thomabb's Avatar
thomabb
I had this happen to my '02. The connector in the column where the multifunction switch plugs in had a couple burnt pins. You have to take the cover pieces off the column to get at it.
Old Apr 28, 2017 | 06:49 PM
99f350sd's Avatar
99f350sd
Old Apr 28, 2017 | 06:53 PM
99f350sd's Avatar
99f350sd
Probably don't have any power into the mfs on the RD....red wire. Sorry the pic is shifted.
Check headlight sw.
Old Apr 28, 2017 | 06:59 PM
DeadFife's Avatar
DeadFife
Checked that before I replaced the MFS infact I changed the connector housings cause mine were broke, of the pins looked good.
Old Apr 28, 2017 | 07:08 PM
99f350sd's Avatar
99f350sd
Old Apr 28, 2017 | 07:12 PM
projectSHO89's Avatar
projectSHO89
If you have power coming into the MF switch (RD/YE) but none coming out where and when it should (RD/BK), guess what?
Don't care how old or new it is.
You still need to verify your readings and observations to keep from getting sidetracked.
delorenzomp
Sep 23, 2018 06:11 AM
44vulcan
Nov 27, 2015 04:37 PM
jnmescape2010
Escape & Escape Hybrid
Dec 23, 2014 07:26 AM
Skylaneman
Dec 8, 2012 12:17 PM
homer4.2
Dec 11, 2009 03:33 AM
