Odd electrical gremlin, SOLVED!
Heater core failed last spring, also decided to replace blend door while in there. BTW, what a pain in the a** to access! Big heavy dash, dropped the column, completed the fix with the help of my wonderful (and tolerant) wife.
(I just hate doing something for the first time, being frustrated, and have a calm and patient person on the other side of the rig giving me positive looks and encouragement. I want to be mad, dammit!)
Now for the electrical gremlin: About a month ago started having intermittent electrical issues. First started randomly lowering and raising front windows, never fully. Felt like the rig was haunted! Then electrical door locks weren't functioning all of the time, randomly locking and unlocking while running. Dash lights and warnings would come on and off, particularly at startup. Then the transfer case would randomly engage to 4HI randomly, particularly when in a parking lot or pulling into/out of driveway, even occasionally briefly into 4Lo when making slow speed maneuvers in a parking lot. Finally got so bad the gremlin began being consistent.
Been looking at all of the connectors under the dash and under the console, even pulling the console out once again. All checked out ok. Physically pulled and jostled the wires under the dash to try to replicate the issue to no avail. Double checked all of the ground connections to make sure they were tight, all ok. Finally, out of desperation, decided to disconnect each and every connector under the dash, clean contacts, dielectric grease, reassemble. No love. Began to clean the grounds on passenger side first, near the kick panel. Lower ground point has two ground wires on one screw/bolt. Found some minor corrosion between the two flat contacts and cleaned them. Reattached body screw to panel, and Voila!, no more gremlins!!
I think the screw may not have been fully tight (felt tight when tugged, checked by hand) and allowed for an intermittent connection for the ground. Each wire has a flat blade about the size of a dime on their end and are doubled up on this ground point. Not having the screw tight allowed for corrosion to begin and progressively get worse. Now corrosion free and tight, no more gremlins.
I hope this can be of help to someone on here as I had scoured the FAQs and queried the search engine in the forum to find a similar problem without any luck.
The numbers are on a White Sticker on the GEM Module
Match the numbers up.
Pull the fuse box to make it easier. Once you get the GEM out, put it in a ziplock with a bag of rice for a couple of days. Let it dry out. The rice will draw any moisture from it.
If it's bad though (I'd bet it's not) you'll have to pull it and swap it out again and that's a pain.
It still works, so it's probably still good.
It probably wouldn't hurt to seal everything up...but the windshield has to be sealed. Flex-Seal might prevent the GEM Module from cooling properly, but I doubt it....
I have to go buy some of that stuff and try my bedliner idea...... if that doesn't work out, I guess I can build a mold and make myself a new girlfriend....
