Ford 9" fluid question
Old Sep 14, 2017 | 11:25 PM
filthy6's Avatar
filthy6
I filled my rear differential today. Took a quart and a half before it started coming out the fill/drain hole. The hole is located at the rear of the diff. I know it was bone dry because the guy who rebuilt it told me to fill it. That same guy and the local Ford community are all in agreement that it should take five pints. Anyone have a guess why I'm two pints shy?
Old Sep 15, 2017 | 12:45 AM
seaves46's Avatar
seaves46
You should have a fill plug on the side of the pumpkin , is it higher than the one on the rear of the housing ?
Old Sep 15, 2017 | 11:46 AM
filthy6's Avatar
filthy6
No fill plug on the side. In better light I found one in the front " honeycomb" part of the diff, BUT, it measures at the same height as the one at the rear. ????????
Old Sep 15, 2017 | 11:49 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you sure the rebuilder didn’t put "some" oil in, to prevent rust, etc.?
Old Sep 15, 2017 | 12:06 PM
filthy6's Avatar
filthy6
That was my thought. Difficult to know for sure. Don't know if the work was done in the morning or the afternoon.......if you know what I mean......He said he gave it to me bone dry. He even put a piece of tape on it reminding me to fill it. I'm going to try to find a different way to approach the subject. I have respect for his knowledge and skill. He has helped me a lot.
Old Sep 16, 2017 | 04:52 AM
fordslut's Avatar
fordslut
is it for a dragster and very narrow?
Old Sep 17, 2017 | 03:01 PM
filthy6's Avatar
filthy6
NO, but it does bring up a question. On initial fill and before start up is the 5 pints confined to the center housing or should some migrate into the axle tubes?
Old Sep 17, 2017 | 03:06 PM
fordslut's Avatar
fordslut
when you go around a corner it goes where it wants, thats fer sure.
Old Sep 17, 2017 | 03:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
A lot of oil clings to all the gears, too. I'd drive it a mile or two, let it settle, and top up. As said, going around corners will get it out in the tubes.
Old Sep 17, 2017 | 05:46 PM
Ct70's Avatar
Ct70
You might try jacking the rear up one side at a time for 15-20 minutes to make sure you have oil to the bearings ,then re checking the level .
Old Sep 17, 2017 | 05:51 PM
Flat Ernie's Avatar
Flat Ernie
I generally fill through the vent...often much easier and I put in how much I want.
Old Sep 17, 2017 | 06:16 PM
fordslut's Avatar
fordslut
I just filled a newly rebuilt 8 inch rear through the brake line vent brass "Y" in the top of one of the tubes. another way to fill/empty is to jack up on one side, and pull an axle out. a bit "shade tree", but it works. just don't mess up the seal.
Mr Dave73
1997 - 2003 F150
Sep 13, 2007 09:58 PM
Antelope V-10
Nov 13, 2006 08:21 AM
1stexpy
May 25, 2005 06:46 PM
truckalpers
1997 - 2003 F150
Dec 2, 2004 06:33 PM
Pastmaster
May 22, 2002 09:20 PM
