Will main tank fill from aux b4 empty?
I have an 80gal aux tank that I hooked up from the drain valve to the neck of the main tank (with deezee kit). 50 minutes ago I filled the aux tank with 20 gallons of diesel and the fuel guage read just above 1/4 tank. Now, it's still about where it was (maybe a 32nd or 64th fuller). I'm wondering if I start off with a full main tank and full aux tank on a trip if it will keep the main tank full (keep up with the usage of fuel). I opened the filler cap on the main tank and can hear it trickling in but the rate is what bothers me.
When I ran the line I didn't go straight down under the bed because there was a hole already just 12 inches away so my fuel line is routed horizontal to that hole then down then horizontal under the bed and to the nipple on the tank. Hopefully you all won't say it has to go on an incline down to the tank because that is hard. Tank is towards the cab on the passenger side and fuel neck at the back drivers side.
I'll have to find the plug and measure it tomorrow but this is the fuel line I'm using.
This is one of the main reasons why I purchased an ATTA 45RBR with the fuel pump system. I wanted positive control over the fuel flow, and I have that with a large momentary switch I installed in the center console.
This was one of the best modifcations/upgrades I did for my truck. Loaded with the 5 wheel I get ~900 miles in range and without I get ~1400 miles in range. Stopping when I want instead of when I have to is great. Also, I get a kick out of watching the fuel gauge go up as I am rolling down the interstate at 65 MPH.
I am 99% sure this is the fuel pump that came with the kit. Another plus as I can get this or something similar to it anywhere.
https://www.oreillyauto.com/detail/p...e16371/4615545
I get the same flow rate with the cap off or on to the main fuel tank (as well as cap off of the tank).
The kit I got that you cut into the filler tube has a ball valve on it. If fuel comes up in the neck it pushes the ball closing the aux tank. I guess if a person left the pump on it would have an overflow situation but I plan on doing what Sous does and turn it off when it gets nearly full. I'll definitely have to keep track of the gallons.
Now you have me thinking! Cylindrical tank 24"x36" under my flatbed in front of the drivers rear wheels. Switch and a pump to pump into the oem tank hmmmm.....
This switch setup is good so that you don't forget that it is on and overflow the main tank. Also, it gives you 100% control over the flow of fuel into your main tank.
rdemilt
03-18-2015 03:22 PM
gracjm
05-21-2007 03:38 PM
