5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
5.0 power steering pump conversion
Old 09-13-2017, 06:08 PM
JacobJ's Avatar
JacobJ
JacobJ is offline
Does anyone know of a power steering pump bracket that I can use on a f150 5.0? I have seen a kit for sale that is advertised as fitting the 5.0 mustang engine, do they share the same accessory pulley system? Also I would like to keep the air conditioning pump if possible. I am planning a 2011+ 5.0 swap into a 1974 ford.
Another question- do all 2011 to 2017 5.0 f150 engines share the same accessory / pulley system or were there changes?
Thanks!
Old 11-27-2017, 10:05 PM
bryangtho's Avatar
bryangtho
bryangtho is offline
Yes i pretty sure vintage air has a full kit
Old 01-18-2018, 11:15 AM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
Thumbs up Coyote PS conversion
I have 2nd generation Coyote crate package. I installed the Power BY The Hour kit. It mounts the pump low on the left side and the alternator high, reversed on the right. It takes some cutting of the timing cover and you have to use the alternator from a Mustang Cobra, that is the only one that can be used. Not cheap but a really good conversion. Around $1200. For everything including the alternator that has to be purchased from Ford.
Hope this helps, Kenny
Old 01-18-2018, 11:33 AM
JacobJ's Avatar
JacobJ
JacobJ is offline
After adding up the costs of all of the things for a modern 5.0 swap, I went over to the dark side. 2015 chevy 5.3 in my F250. Low mileage engine was $1500, power steering conversion kit was 200.
Old 01-18-2018, 03:24 PM
bryangtho's Avatar
bryangtho
I'm putting a 2017 coyote in to my 1956 f100 and i was going to use a vintage air kit. But couldn't get it to work because of the Edelbrock supercharged. Over here vintage air kits are like $2700 for power steering and ac. Anyway for the power steering i went with a holden astra power steering pump which i can get for a $150 at the wrecker
Old 01-18-2018, 03:34 PM
kenny nunez
Power steering.
Have you given any thought to a non power steering rack. I would have done it that way but my wife likes the truck and wants to drive it also. Too bad that the AC conversion is that expensive “Down Under”.
Old 01-18-2018, 03:38 PM
JacobJ's Avatar
JacobJ
JacobJ is offline
Do you have any pictures of astra power steering pump install? and which brackets are you using, the vintage air?
Old 01-18-2018, 03:39 PM
JacobJ's Avatar
JacobJ
JacobJ is offline
A truck without power steering? I guess I could cancel my gym membership haha
Old 01-18-2018, 03:48 PM
kenny nunez
Power steering
Back in 1974 when I installed a 460 in my 68 it had a 4 speed and manual steering. Of course the wife complained but she still drove it. Now that we are in our 70s, well, you get the idea.
Old 01-18-2018, 04:18 PM
bryangtho's Avatar
bryangtho
I went with the factory AC which just left me the power steering. I don't have a picture of it installed but this is the one that i will be using
Ky1950
23
02-06-2018 06:40 PM
Michael Levy
05-04-2015 04:06 PM
jjpeach
02-27-2015 11:24 AM
Boz Turner
12-16-2006 07:43 PM
mauicruza
1966 - 1977 Early Broncos
12-26-2005 01:42 PM
Quick Reply: 5.0 power steering pump conversion
