1954 F100 Power Steering Conversion 223
Getting ready to get a kit from mid fifty to convert to power steering. Most of the posts pertaining to installing the ps pump and bracket are from 5 or 6 years ago. Right now I have a 12v system with a generator in original position on driver's side. Should I build a bracket? Where to install? Are there any pre-fab brackets on the market? Electric fuel pump? Replace generator with alternator first? So many questions, I know, but I want to do this right.
https://www.ford-trucks.com/forums/1...r-of-love.html
This is the "new" way to go
y block power steering bracket | eBay
This is the stock way of doing it
DinnerHill SpeedShop: Power steering
Then you have to decide where to take the power from
Originally it came from a 2 belt harmonic damper like this
DinnerHill SpeedShop: NOS 2 belt Harmonic Balancer, Ebay find.
It will be a tight fit for the lower waterpump hose, there are a lot of different eaton pumps so it might be a bit of a challenge to find one that reaches far enough.
I have a long nose pump and that seems to work, I have just mocked up everything briefly
http://www.stangerssite.com/eatonpumppics.html
53rat
08-01-2020 12:00 PM
callforfire
47
03-30-2020 01:53 PM
ROCKY1956
06-20-2006 09:15 PM
