5.0 power steering pump conversion
Does anyone know of a power steering pump bracket that I can use on a f150 5.0? I have seen a kit for sale that is advertised as fitting the 5.0 mustang engine, do they share the same accessory pulley system? Also I would like to keep the air conditioning pump if possible. I am planning a 2011+ 5.0 swap into a 1974 ford.
Another question- do all 2011 to 2017 5.0 f150 engines share the same accessory / pulley system or were there changes?
Thanks!
Thanks!
Coyote PS conversion
I have 2nd generation Coyote crate package. I installed the Power BY The Hour kit. It mounts the pump low on the left side and the alternator high, reversed on the right. It takes some cutting of the timing cover and you have to use the alternator from a Mustang Cobra, that is the only one that can be used. Not cheap but a really good conversion. Around $1200. For everything including the alternator that has to be purchased from Ford.
Hope this helps, Kenny
I'm putting a 2017 coyote in to my 1956 f100 and i was going to use a vintage air kit. But couldn't get it to work because of the Edelbrock supercharged. Over here vintage air kits are like $2700 for power steering and ac. Anyway for the power steering i went with a holden astra power steering pump which i can get for a $150 at the wrecker
Do you have any pictures of astra power steering pump install? and which brackets are you using, the vintage air?
Michael Levy
05-04-2015 04:06 PM
jjpeach
02-27-2015 11:24 AM
Boz Turner
12-16-2006 07:43 PM
