Onboard Air
Old Sep 8, 2017 | 02:21 PM
ERock62's Avatar
ERock62
Onboard Air
Thinking about getting an onboard air system for my F250.
Need something that can fill 35" tires (37" in the futures maybe) and also fill the tires on my Toy Hauler.
We do a lot of desert/sand camping and I often air down.
Anyone have any opinions/options? I know Viair makes some nice units. Another option (cheaper) would be get a pancake compressor and run off my generator.
Old Sep 8, 2017 | 04:19 PM
Pwrgeek's Avatar
Pwrgeek
My 2015 got a $99 harbor freight pancake that ran off the inverter. The 2017 is getting dual Viair constant duty units.
Old Sep 8, 2017 | 04:50 PM
ruschejj's Avatar
ruschejj
Viair #10009 I think. Dual 100% duty cycle compressors with a 1.5 gal tank
Old Sep 8, 2017 | 05:05 PM
rick danger's Avatar
rick danger
i want to put airbags in my new truck. I was looking at the wireless type for the onboard compessor so I dont have to make holes to run a gauge and control into the cab. is there an OBA setup that I could have that would give me air for tires and for the airbags? I dont think the little compressor for the airbags would inflate a tire. Maybe something that would have a wireless gauge and control for the bags but with a bigger heavy duty compressor to do the filling? Then a tee off to a quick coupler for an air hose? Wondering if anyone has done something like this.
Old Sep 8, 2017 | 05:24 PM
ruschejj's Avatar
ruschejj
I have a viair system that I really like. It's 2 compressor motors feeding a 1.5 gal tank.
For airbags I just ran a line from the tank to my manifold in the cab, then from the manifold to the airbags. I have an air pressure gauge for the airbags with the valve for fill/drain. There is another gauge with power switch for the viair system.
Sounds and seems complicated but it's not. It's been a reliable system (over 2 years now) and I use it nearly every day.
Viair #10009
Firestone #2535 (2015 f350srw kit)
The modern equivalent should be just as nice.
Old Sep 8, 2017 | 05:34 PM
Pwrgeek's Avatar
Pwrgeek
This is exactly my plan. Viair dual constant duty compressors with a tank. Airlift wireless one system. Just throw the little air lift compressor away and run a line from the Viair tank to the airlift manifold where the compressor would normally go. At least that's the plan right now. I may need to add a 12V air solenoid in that line so that the airlift manifold doesn't have pressure on it all the time. Then just run the airlift wire that would normally trigger the compressor to that solenoid instead. We'll see how it works in a month or so when my truck shows up.
Old Sep 8, 2017 | 11:56 PM
ERock62's Avatar
ERock62
Thanks! That looks to be exactly what I am looking for.
Do you have any photos of it mounted?
ExDakotaOwner
Aug 31, 2016 06:21 PM
Scooter22
Aug 6, 2016 07:22 AM
bearpa
Jan 11, 2012 07:52 PM
89LX306
May 17, 2011 08:53 AM
bshackelford711
Jun 18, 2009 03:56 PM
