Newby and needs help
Old Sep 7, 2017 | 01:17 PM
Revtech100's Avatar
Revtech100
So I just picked up a 1993 f250 with the 351W. I replaced the ignition switch and it started just fine. I replaced the headlight switch and connector and it started just fine. While I had it apart I decided to check and replace the instrument panel lights. Didn't replace any yet. But after I put it back in the truck cranks just fine but will not fire. No start. Any advise?
thanks
Old Sep 7, 2017 | 02:10 PM
Scndsin's Avatar
Scndsin
If the tank select switch is currently undone while you have the cluster/instrument bezel open, it won't run.
Did you rep the key cylinder or the switch down the column?
Old Sep 7, 2017 | 03:12 PM
Revtech100's Avatar
Revtech100
i replaced the key cylinder. I don't have dual tanks but it's got a place to plug it in. So I plugged it in and it started right up! Thanks a million. I really appreciate the help!
Old Sep 7, 2017 | 08:11 PM
Scndsin's Avatar
Scndsin
Glad it worked.
Welcome to FTE.
billrigsby
Apr 15, 2015 05:40 PM
78bigunns
Sep 24, 2014 05:50 PM
zzjonze
Jun 20, 2007 09:30 PM
aka rotten
Jun 8, 2005 03:50 AM
ftrain
Aug 13, 2002 10:28 AM
