1978 - 1996 Big Bronco
IAC question
Old Sep 8, 2003 | 07:30 PM
96bronco58's Avatar
96bronco58
IAC question
Just pulled my iac ohms are ok supply voltage is ok. My question is about how it should operate. My conclusion (correct me if im wrong) voltage supplied' valve closes. Without supply voltage valve opens via spring inside iac. On mine spring seems weak (does not want to open valve) and with voltage supplied does not want to close from open position. Am I correct in my thoughts on its operation, and need to replace it, or am i wrong and it is possibly fine. Also valve seems to take too much effort to move manualy. Thanks for any input on this.
Old Sep 8, 2003 | 08:01 PM
DW2455's Avatar
DW2455
IAC question
try cleaning the valve with some carb cleaner. DW
Old Sep 8, 2003 | 09:16 PM
96bronco58's Avatar
96bronco58
IAC question
Thanks DW. Am i correct in how it is supposed to operate. I have never dealt with one b4 and am not sure. I also just used a programmer on my truck and it has held it idled high and fluctuating. I pulled plug on iac and it went right back to normal. If the iac is to any certainty the problem I think I would rather just replace it than worry about it fouling up again anytime soon. It also seems to have helped the issue I was having with the truck surging on me.
Old Sep 8, 2003 | 10:07 PM
DW2455's Avatar
DW2455
IAC question
well thats your option but considering it easy to get at and dont take 15 min. to change I would at least try and clean it. but thats me. DW
Old Sep 9, 2003 | 10:15 PM
96bronco58's Avatar
96bronco58
IAC question
DW went with the cleaning idea after I saw the price of new iac. But it didnt help, I even soaked the valve portion in seafoam for a while. Wound up havin to drop the 60 bucks for a new one which was the fix. Smoothed the idle back out. Guess that my old program was adjusted to the condition and new one didnt know what to do with it. I suppose there is not a code for the iac as I was not showing any. Anyways wanted to say thanks for the help.
carlsson
Dec 11, 2011 04:21 PM
gmdattilo
Modular V10 (6.8l)
Apr 26, 2011 09:59 AM
TheMonkey
Sep 6, 2008 02:23 PM
hawki_peers
1983 - 2012 Ranger & B-Series
Jun 4, 2005 07:36 PM
F250reddog
Jan 13, 2004 08:31 AM
