Mini Starter Install Problem on '91 4.9
Old Sep 6, 2017 | 11:04 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Since I've been having some no-start issues, I decided to go ahead and install the mini starter I had on the shelf. I opened up the hole on the terminal on the starter end so I could re-use the cable - fastened that to the top lug on the mini starter. All was going fine until I got to the point where I attempted to fasten the other end of that lead to the other side of the starter relay on the inner fender well (supplying 12V+ to the un-switched side of the mini starter at all times). I got a big spark as soon as I touched that end to the relay and if I held it there for a split second the Gnd side of the battery started to smoke!
Thoughts on what the hell is going on here? I've done mini starter swaps before without issue - it's not that difficult. I'm scratching my head on this one right now.
Old Sep 8, 2017 | 10:18 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Have I stumped everyone (including myself)?
Let me add, the starter was an untested junkyard pull. Could it possibly have a short to ground? That's the only thing I've come up with so far.
Old Sep 15, 2017 | 09:35 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
My diagnosis was actually correct. It would appear that the starter did indeed have a short to ground. I swapped in a new starter and all is working fine now.
Afterwards I bench-tested the suspect starter. It grunted a little and then spun fine. Maybe a broke free whatever was causing the short? Nothing fell out though.
ralbach
Jul 18, 2009 08:24 AM
Sweetred95ta
Sep 20, 2006 04:41 PM
97 RED PSD
Apr 22, 2006 09:32 AM
cpettymore7777
Oct 18, 2004 11:43 AM
patmorrison
13
Feb 27, 2004 03:20 PM
