starter just clicks
Old Oct 13, 2004 | 10:13 PM
cpettymore7777's Avatar
cpettymore7777
starter just clicks
my starter only clicked today. even when i bypassed the the starter relay. so i did a trick that my grandfather told me. tap it with a hammer. now it works. this has worked for some other people before. does anyone know why it does?
Old Oct 17, 2004 | 08:58 PM
Trial and Error's Avatar
Trial and Error
My uneducated guess would be that striking the starter with a hammer causes bad brushes to vibrate and make a better connection (temporarily, most likely) If it happens again I would look at replacing brushes in the starter or buying a rebuilt unit.
Old Oct 18, 2004 | 01:17 AM
mustange70's Avatar
mustange70
Yep thats what tapping the starter does, but its a good sign of a worn starter that needs to be replaced or rebuilt. Also that clicking can mean a bad starter soleniod or a dead battery.
Old Oct 18, 2004 | 06:01 AM
Beast12's Avatar
Beast12
Since you tapped the starter and it started up then it is probably your starter. BUT, it could also be that your positive cable to your starter was looke and the tapping somehow made it get a better connection. I would maybe first clean the cable and put it back on and see what happens.
-Matt
P.S. I would keep that hammer behind your seat.....just in case.
Old Oct 18, 2004 | 11:43 AM
MRStace84's Avatar
MRStace84
That hammer trick will for work for a while, but just keep in mind that more than likely it is a sign of a starter going bad, so if you drive this truck much, you probably should consider replacing the starter soon.
