5.4 2v e350 cyclinder 2 missfire
Old Sep 4, 2017 | 11:25 PM
Brian Perry's Avatar
Brian Perry
Change coil pack and plug with OEM parts x 2. Just in case replacement was bad first time. Still getting same code. Fuel trims not the same between st1 and St2 Not sure what to check next. Coil does fire on plug out of head. No codes if I disconnect injector plug and coil to #2 cylinder.
Old Sep 5, 2017 | 10:22 AM
z31freakify's Avatar
z31freakify
Try swaping the injector with another cylinder and see if it follows.
Old Sep 5, 2017 | 12:06 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by Brian Perry
... Not sure what to check next. Coil does fire on plug out of head. No codes if I disconnect injector plug and coil to #2 cylinder.
Check to see if 12v is getting to the coil (RD/LG) and injector (RD) connectors with the ignition switch in Run.
Check to see if 12v is getting from the coil (PK/WH ?) and injector (WH ?) connectors to the PCM connector.
Old Sep 5, 2017 | 08:17 PM
Brian Perry
Swapped injector. No difference still same code P0302- #2 cylinder misfire
Didn't get a chance to check power yet
Old Sep 5, 2017 | 11:48 PM
F150Torqued's Avatar
F150Torqued
The OP did say "coil does fire plug out of head".
If misfire stays on # 2 after swapping COP & Plug to another cyl, I think it is time to swap #2 injector to another location and see what happens.
Old Sep 7, 2017 | 05:49 PM
Brian Perry
Sent it to shop. 63 PSI compression in #2. time to trade it in. First Ford we have had to give us big trouble with under 100k
Old Sep 7, 2017 | 06:25 PM
F150Torqued
Sorry to hear that.
From a 5.4L 3v owner with 226K and going VERY strong. (Did a timing chain job recently) - but avg 170 PSI compression and recent careful check revealed 1 qt consumption in 2600 miles.
Good luck - (on your next FORD).
Old Sep 7, 2017 | 07:12 PM
z31freakify
Did they do a leak down test? To make sure it wasnt a burnt/bent valve.
Old Sep 9, 2017 | 10:28 AM
Brian Perry
No leak down test done.
speedracer54729
Modular V8 (4.6L, 5.4L)
Aug 11, 2019 07:27 PM
Gary Culy
1997 - 2003 F150
Jul 2, 2019 09:57 AM
Eric3131
Dec 3, 2017 10:04 AM
URDADDY
Feb 16, 2011 11:56 PM
jjlrrw
1997 - 2003 F150
Aug 15, 2006 08:42 PM
