coil packs?
Old Feb 14, 2011 | 02:05 PM
URDADDY's Avatar
URDADDY
coil packs?
2003 Expedition, 4.6L, 140,000 miles.
This is the wifes expedition. She told me it was running a bit rough and the service engine soon light came on. I took it for a ride and could tell it was missing pretty bad. Went to the local parts store, they hooked it up to the diagnostic tool and it showed misfire on #1. I went ahead and bought a new coil pack and took it home. Disconnected neg. battery cable and installed the new coil pack on #1. Now the thing seems to be running even worse but the service engine soon light is not coming on. Tried to check it for codes but no codes. What gives?
Thanks
Old Feb 14, 2011 | 03:24 PM
pdqford's Avatar
pdqford
Just an FYI, but a coil pack has spark plug wires and serves multiple cylinders. A COP (Coil On Plug) connects directly to the spark plug and servers one cylinder.
Now the thing seems to be running even worse but the service engine soon light is not coming on. Tried to check it for codes but no codes. What gives?Thanks
Might want to get back in there again and swap the spark plug with cylinder #3's plug and swap the injector with cylinder #2's injector and see if it eventually sets a code for one of those cylinders. (If it still says #1 is misfiring you may have a poor connection at the coil primary or the injector power/ground circuit for cylinder #1.
Old Feb 14, 2011 | 07:42 PM
alloro's Avatar
alloro
Why? What if it was just a bad spark plug or an injector?
Old Feb 15, 2011 | 12:31 AM
URDADDY's Avatar
URDADDY
How can I tell if it is a bad injector? And why would it run bad but not give another code?
Old Feb 15, 2011 | 06:02 AM
Moto Mel's Avatar
Moto Mel
It will in time. Check the wire connections at each of the injectors. You may have popped one off.
Old Feb 16, 2011 | 08:00 AM
broncoholic's Avatar
broncoholic
Are you certain you changed the right coil? I had a misfire recently and installed a new spark plug at the cylinder the parts store guy told me was #7. When the misfire was still there, I looked up the cylinder numbers on a hunch and found that he had the sides reversed and had me change #3.
As for the code not being there, they take a certain number of instances to occur and/or trips to be made before the code sticks.
Old Feb 16, 2011 | 05:04 PM
N832's Avatar
N832
I always start with changing plugs with misfire codes. Use a motorcraft or autolite plugs. I have found in the past anything else doesn't work very well in Fords. Make sure you gap them. They do not come pre gapped as I have heard parts people tell poor souls who believe them. Should be .054", but double check that.
Old Feb 16, 2011 | 07:47 PM
URDADDY's Avatar
URDADDY
I went ahead and ordered all new coil packs and scheduled to have the shop do the plugs and coil packs. And yes I know I can save some money and do it myself but that back plugs look like a pain and I just dont really have time to mess with it.
Old Feb 16, 2011 | 11:56 PM
buddyp's Avatar
buddyp
Thanks
hope its already fixed but if not check ground from cab to frame sounds "CRAZY" but i have a 2002 F250 superduty engine light never worked un till yesterday because i to have had coil probs always had to pull wires and guess for 5 f@!#$% years seen it broken but never thought much of it mechs said it did not matter well i changed it YESTERDAY and the light works go figure good luck
kalpesh
Jan 31, 2013 09:07 PM
wifebeaterhitman
15
Nov 8, 2012 04:16 PM
cwalsh540
1997 - 2003 F150
Nov 19, 2009 10:07 PM
bigredaggie
1997 - 2003 F150
Sep 30, 2004 12:27 AM
mcn420
Sep 23, 2004 09:05 PM
