Cruise control button bench test
Old Sep 4, 2017 | 05:56 PM
Tepco's Avatar
Tepco
Can someone help me with bench testing cruise control buttons on a 1997 Club wagon E350? I have replaced the clock spring, tested the switch on the master cylinder, replaced the abs sensor on the rear diff. I have no lights, engine, ABS or airbag, speedometer is working fine, so I'm assuming its bad switches.
Does anyone have the bench test procedure for this? Only thing I can find is a youtube video for a ford mustang.
It is a OEM system.
Thanks!
Old Sep 12, 2017 | 07:42 PM
Tepco's Avatar
Tepco
I really need help getting this cruise control working. I'm stumped. I tried another set of buttons from the salvage yard and still nothing. Yes they can be bad as well but I cant find a way of bench testing them.
Old Sep 12, 2017 | 07:55 PM
Im50fast's Avatar
Im50fast
That's an odd request. Never seen anyone ask a similar question on here before.
I assume they are just momentary push buttons. Hook up a multimeter to each side and then they'll show continuity when depressed. I say this based on basic electrical skills, not specific knowledge of your issue.
Have you tried this type of test?
have you checked the fuses?
Old Sep 12, 2017 | 08:52 PM
Tepco's Avatar
Tepco
Yes I have checked the fuses. There is a check for Ohms range for each button and a bunch of new OEM buttons sent out were out of spec and didnt work (as explained on the youtube video)
So I was trying to find the specific ohms for the E models.
Old Sep 15, 2017 | 09:31 PM
annaleigh's Avatar
annaleigh
have you checked the recalls for your van?
https://www.cars.com/recalls/ford-e350-1997/
Old Sep 15, 2017 | 09:54 PM
annaleigh's Avatar
annaleigh
https://www.autosafety.org/ford-crui...s-and-history/
Old Sep 16, 2017 | 07:05 AM
Wildman25's Avatar
Wildman25
Have you checked vacuum to the Servo motor?
Cracked or broken vacuum line could cause this problem.
Could also be a broken wire inside the steering column, had that on a Cherokee one time.
Old Sep 16, 2017 | 09:03 AM
Tepco's Avatar
Tepco
Its an electronic servo motor so no vacuum lines, I replaced the clock spring with an OEM unit and am getting readings at the service harness so I assume the connections are good. It seems the buttons are not sending the proper ohm readings. I'm testing another set of buttons this weekend.
Old Oct 1, 2017 | 03:34 PM
Tepco's Avatar
Tepco
Ok just to follow up. It was the buttons. I had a frozen servo motor that i replaced, (cruise still didn't work) so I sourced out a set of buttons that tested good on the on and set, from the salvage yard. So now the set, resume, coast and accel work. Off doesn't but the brake shuts it off. So now I will look for a good deal on a new set. 1997 buttons are different then most other years.
evil_edwardo
Oct 27, 2015 09:38 AM
onelowhog
Electrical Systems/Wiring
Mar 28, 2015 04:21 AM
terrym041
Oct 18, 2013 04:18 PM
Jkelley
Dec 11, 2012 10:50 AM
mah77
Jun 30, 2011 06:04 PM
