Sponsored by: Real Truck
Cruise control help please?
Old Mar 25, 2013 | 09:42 PM
terrym041's Avatar
terrym041
Hello I have a 2003 f-250 5.4l and the cruise control quit. If you press the on and coast it will honk the horn so im thinking switches on the steering wheel or the clockspring. I need to test those. Does anyone know how. everything else works fine
Old Mar 26, 2013 | 05:45 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like a clockspring issue.
Old Mar 26, 2013 | 05:09 PM
terrym041's Avatar
terrym041
Do you know how to test the clockspring?
Old Mar 26, 2013 | 08:50 PM
projectSHO89's Avatar
projectSHO89
That's normal. It's a bit of an "Easter egg".
The most common failure in the cruise system is the pressure switch (SCDS) on the master cylinder, the subject of recall 05S28 (SEARCH for it...)
Old Mar 27, 2013 | 06:38 AM
redford's Avatar
redford
Basically, you test each wire of the clock spring with a VOM for continuity.
Old Oct 18, 2013 | 03:01 PM
terrym041's Avatar
terrym041
cruise control fixed
i fixed it. it was the clutch position switch easy to check pop it out and look inside my springs were corroded and broke not allowing it to move inside the vehicle would still start though
Old Oct 18, 2013 | 04:18 PM
SC_Hoaty's Avatar
SC_Hoaty
Did you happen to take any pics?
njstevens
Oct 1, 2021 09:41 PM
TheGageinator
Jun 25, 2015 04:37 PM
bruno2
Aug 29, 2011 06:13 PM
IMPRTKLLRZ28
Dec 7, 2010 10:55 PM
WOLFBAYOU
Dec 18, 2002 05:57 AM
