Looking for drain plug information
Old Sep 4, 2017 | 04:44 PM
skyfox10's Avatar
skyfox10
Arrow Looking for drain plug information
Ok. This is for my 96 with 351.
When I bought this truck 9 years ago, the drain plug was on the border of being rounded off. I've been very careful with it over the years and always get it started with a flank drive impact socket. Today I did an oil change and I have decided that the plug finally has finished it's useful life.
I am looking for a replacement drain plug. My first question is, is the plug size 1/2 inch 20 thread or something else? I don't want to waste time looking for the wrong size plug.
Secondly, are there certain aftermarket brands that are better than others? I wouldn't mind having a magnetic drain plug, so if there is a quality aftermarket source, I would be interested.
If there are good magnetic aftermarket plugs out there, does anyone know of one that has the original 5/8" hex head? If I can't find one with original dimensions, I will probably look for an OEM part.
Thanks for any help on this.
Old Sep 4, 2017 | 11:40 PM
mrollings53's Avatar
mrollings53
Go to your local O'reilly's. You'll find them across the aisle from the engine oil.
Old Oct 5, 2017 | 09:30 PM
skyfox10's Avatar
skyfox10
Ok, this thread didn't seem to garner much attention. I guess it makes sense, as most people don't spend a lot of time thinking about drain plugs. Just thought I would post an update, in case someone else is looking for this info in the future.
I went to ford and bought an OEM plug. The part number is F75Z-6730-BA. The listed specs for this part are 14mm x 1.50 with a 16mm head. A 5/8 6-point socket fits on the head without any trouble.
Other specs: Length under Head: 20mm / Washer Head OD: 28mm
Old Oct 5, 2017 | 10:15 PM
wtroger's Avatar
wtroger
I didn't think the SBF Windsor engines used metric drain plugs
Old Oct 5, 2017 | 10:44 PM
skyfox10's Avatar
skyfox10
Neither did I. I was really surprised when I looked up the specs for the part they gave me. I really wish I wasn't 1600 miles away from my next oil change so I could try it out.
Old Oct 6, 2017 | 01:47 AM
GoinBoarding's Avatar
GoinBoarding
I've got a Gold branded magnetic drain plug. Original is in my toolbox, needs new grey paint but otherwise fine. Mag plug takes a 3/4" socket, and if I recall correctly, it was indeed metric thread.
sheevesakatyler
Jun 8, 2019 08:03 AM
JDDINMINN
Feb 2, 2018 08:43 PM
Mikeyg76
2009 - 2014 F150
Jun 3, 2016 12:09 AM
HD
Oil & Lubrication
16
Jun 11, 2003 05:49 AM
56efffie
Feb 27, 2003 12:34 PM
