48-52 door regulators
Old Sep 2, 2017 | 08:05 PM
3twinridges's Avatar
3twinridges
got the door and window regulators out today. Would it be better to media blast them or soak in evaporust? I am afraid evaporust would get into the bearings but have the same fear over the sand?
JB
Old Sep 2, 2017 | 08:11 PM
abe's Avatar
abe
How rusted are they. They will be in your door, no one is gonna see them.
Old Sep 2, 2017 | 09:06 PM
3twinridges
They are not in good shape that's for sure and I hate to put them back in like this!
Old Sep 2, 2017 | 09:39 PM
drptop70ss's Avatar
drptop70ss
I wire wheeled mine and then lubed all moving parts with wheel bearing grease. Stays in place and I like it better than white lithium grease.
Old Sep 2, 2017 | 11:19 PM
pweng1's Avatar
pweng1
I soaked mine in the molasses then cleaned them up. I think it worked well.
Old Sep 3, 2017 | 10:25 AM
544tess's Avatar
544tess
I would scrap off the old gunky grease on the window regulators then take a wire wheel to them.
I used motor oil to lube them.
Do the shafts have a lot of play?
I tightened the shafts on mine by swaging the shaft support.
Took a piece of galvanized pipe (1/2" ID I think) I had and chamfered one end.Placed the pipe over the shafts with the opposite end supported and hit with a hammer a few times.
This tightened the shafts up.
I ended up buying rebuilt door regulators from Mid Fifties because of broken springs.
Old Sep 3, 2017 | 02:13 PM
petemcl's Avatar
petemcl
Since they are not going to be visible I would do as Dave suggests, just use a wire brush or wheel. Then on the parts that have rust I would just use Eastwood Rust Converter in the plastic bottle. It is an easy cleanup with water. Let it dry overnight then you can paint it with black or silver rustoleum if you wish. No UV will get to the part so a topcoat would be optional.
Old Sep 3, 2017 | 02:17 PM
dadgonebroke's Avatar
dadgonebroke
door reg.
I don't think the door regulators are that expensive or at least they weren't on my'56. And your door reg. isn't in good condition.
Old Sep 3, 2017 | 03:59 PM
schoo's Avatar
schoo
Dave(drptop70ss) has a good tutorial on the door regulator rebuild ck it out
Old Sep 7, 2017 | 08:22 PM
3twinridges
So.....I upgraded to better regulators. I think I am going to buff them out with a small stainless wheel and clear coat them
Old Sep 9, 2017 | 10:00 AM
tip49's Avatar
tip49
That's better !
I don't think you will be sorry you upgraded. And you can collect (hoard) the old ones for spare parts, just in case.
freejay
Jun 7, 2016 01:20 PM
bigblockford_390
Nov 29, 2010 05:10 PM
DZL JIM
20
Feb 26, 2009 05:07 AM
B/B ford
Jul 16, 2006 03:10 PM
