Oil and transmission fluid
So I have this 82 F150 that I got 3 weeks ago. Needing to change fluids. I haven't worked on vehicles ever and this is my first rodeo. Please bare with me if I ask questions that I should know the answer to. The truck has the 4.9 inline six and the t-18 manual transmission. What weight oil is recommended for this engine at this age and what should I use for the transmission fluid? I ask about the transmission fluid because I saw that someone on here used motor oil before and then was told to use an automatic transmission fluid.
Thanks, Mark
Thanks, Mark
I asked the same question some months ago. I had good sucess with diesel 5w40 in my 4.9, and it almost stopped the loss/seepage I was experiencing from the pan gasket. Many run 10 w 30. Many say you can run anything in that engine and not kill it! Diesels with more zinc may be better for our flat tappet 4.9. I am simply parroting what I've read here, BTW.
One of many discussions in the oil and lubrication forum.
https://www.ford-trucks.com/forums/1...what-type.html
NOT all of them have high zinc because new diesels now have cats.
They also don't have as much anti-foam as a diesel dose not turn the RPM a gas motor does but the 300/six does not turn too high either.
A good high mileage oil (should have more zinc)in a 10w-30/10w40 or 20w-50.
Think I bought 10w-40 for mine for when I go to start it.
Dave ----
Now there was a post on watch the label as some of the newer gear oil is not kind to brass parts inside.
Dave ----
JStoddard1
10-07-2008 03:18 PM
John with beastly 302
Oil & Lubrication
12-31-2003 09:29 PM
