What can I do with 35 gallons of old gas?
there is a schrader valve on the fuel rail by the valve cover as alloro said. Turn the key on , the fuel pump should run, then shut off after 3 seconds.......... go to the Schrader valve and poke the center pin ( not at your face) and see if you get a short squirt of gas out of the valve. Should have 30 psi or better if pump is working and fuel in the lines.
abeagle
11-12-2014 03:07 PM
